Old 02-14-2016, 10:54 PM   #851 (permalink)
Thanks. I have changed all the prog_char with const char (ctl-f) and physicaly substitute one for the other, but without sucess. I understand some of you made profi with this, but I'm at my begginings in programing so I would appreciate guidance has to what is going on... The compiler is just reporting way too many errors and that tells me something fondemental I'm not doing well.
Best regards.
Old 02-15-2016, 08:08 AM   #852 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
I think it is because the code was done with an old IDE, it does not work with 1.0+, you have to install a 0.xx version
2013 Hyundai Sonata Hybrid
Old 02-15-2016, 11:37 AM   #853 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I was able to convert the code to use the newest IDE, but I am not at all sure it will work. Does anyone want to test it?
Old 02-15-2016, 01:46 PM   #854 (permalink)
@Magister
You are a genius my freind
I have unistall version 1.6.5 of IDE and installed an old 1.0.6 that I have found over the net and now it compiles and load everything without errors
Now I got to work on the interface for a kw1281 protocol. I have a few options there for level shifters mc33290, L9637 or individual opto-isolators.
Old 06-25-2017, 07:20 PM   #855 (permalink)
Hello.
I have a simple task to achieve, I guess, but I'm stuck. All I need to do is to read the Speed of the vehicle using data from the obd2 k-line pin, and then to send a command to blink the brake lights when a certain decrease in speed is detected (e.g. more than 2km/h/s). I can not initialize the k-line and I am not able to read anything on the serial monitor on arduino . The vehicle is an 2004 BMW E60, uses ISO_14230_fast but I guess this is not an issue.
So, all I need Is some help from someone to extract from the code only the part for init sequence for ISO_14230_fast and sone way to read the speed on the serial monitor.
Old 03-16-2018, 08:47 PM   #856 (permalink)
Hi , tank you for obduino project ,I am sorry my English not good , I want build mpguino by arduino uno +serial elm327 but I can't found sketch code for that , I found obduino32k and removed comment from define elm but code not compile ,if you have update code send for me pleas
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
