Old 07-23-2014, 04:52 PM   #6731 (permalink)
EV Connoisseur
Okay.. turns out that my serial code was still a little buggy.. sending commands did not work and receiving sometimes went wrong.
Looks like I've got that fixed now.. things seem to work reliable.
I can now start and stop rtd data from my command line running on the raspberry.
Paul, I'm having a hard time finding out what the values mean.. can you tell me?
I mean the:
TR=throttle.. but what is the rest? CR= CF= PW= HS= FB=?
Old 07-23-2014, 04:58 PM   #6732 (permalink)
PaulH
MPaulHolmes's Avatar
Don't worry, my serial code is probably buggy too. haha. CR I think is current reference?? (throttle position on a scale of 0-512 I believe). CF is current feedback on a scale of 0-512 at the moment. So, if max motor amps is programmed to be 100 (per IGBT haha), the current feedback of 512 would mean that IGBT (I'm only making use of 1 of the sensors at the moment) was passing 100 amps.
PW = pulse width (pwm duty), on a scale of 0-512 probably.
HS = heat spreader temperature. Basically the base plate temp. A raw value. Just what the A/D value is, in the range of 0-1023.
FB = fault bits.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
flores (07-24-2014)
Old 07-24-2014, 04:11 PM   #6733 (permalink)
EV Connoisseur
Nice.. and RT? BA?
Old 07-24-2014, 04:15 PM   #6734 (permalink)
PaulH
raw throttle (just the A/D conversion result, usually in [413, 683]) and Battery amps.
kits and boards
Old 07-24-2014, 04:35 PM   #6735 (permalink)
EV Connoisseur
It is actually going to work.
Here you see, on the left the service running on the raspberry, and on the right the raspberry serving html with the config of the controller.
Still needs A LOT of work... but it's going to be utterly cool.
The Following User Says Thank You to flores For This Useful Post:
MPaulHolmes (07-24-2014)
Old 07-24-2014, 04:37 PM   #6736 (permalink)
EV Connoisseur
Paul.. that uart ttl tap off on the controller board.. could you make that 3.3v at the transmitting side, with a resistor voltage divider? Than we can directly connect the raspberry.
Old 07-24-2014, 05:05 PM   #6737 (permalink)
PaulH
Heck yes I can! That is very very awesome...
kits and boards
Old 07-24-2014, 07:54 PM   #6738 (permalink)
PaulH
I got to see (I think) the VLA500-01R go into thermal cutback today. It's around 50degC in my shop, and it starts to cut back its maximum current at around 56 degC. Even with no power going out of it, just turning it on uses around 150mA and gets warm. So, I was sitting in the house minding my own business, out of the 115degF weather, and I started to hear the A/C sound like it was pulsating a little. Fast, slow... I go outside, and the darn thing is turning off and on the pwm about 1 time a second. This could have been a significant problem if it was in a motor controller. The pwm could have been ramped up to 100%, trying to see current feedback (since the VLA500-01 tells no one about its thermal cutback). Hmm... Just an FYI for all the people out there that live in 180degF weather that are driving around with a VLA500-01R.
kits and boards
Old 07-25-2014, 06:16 AM   #6739 (permalink)
ready to cool that **** down
The Following User Says Thank You to 4x4EV For This Useful Post:
MPaulHolmes (07-25-2014)
Old 07-25-2014, 11:34 PM   #6740 (permalink)
Hi Paul,
New controller arrived!!
Its taken some minor damage from the post - not bad
I'm not allowed to do anything with it until I have finished doing some decorating!
I will send some pictures after I get the bedrooms papered
The Following User Says Thank You to duncan For This Useful Post:
MPaulHolmes (07-26-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
