05-29-2018, 08:47 PM
Cyborg ECU
Potato power
"Spherical back pressure oscillation" he calls it. I would post this in the lounge or the unicorn corral but he has it on a dyno, so it must be science!
I looked it up in the Google without much success. Something called the Helmholtz effect comes up, but it seems unrelated.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
05-30-2018, 02:02 AM
That was mighty fun. And funny.
It's likely that the straight pipe is a bit too big, and adding the potato increases the exhaust velocity at the tip, allowing for quicker exhaust flow.
But the rest of the results, 49.9 to 51.6 kw is not a big difference, and without A-B-A testing, it could simply be an old motor shaking the cobwebs out on successive runs... especially if the previous owner never really revved it out.
The Following User Says Thank You to niky For This Useful Post:
05-30-2018, 05:06 AM
06-01-2018, 08:16 AM
Will I make more power with a cannon on my car?
That'll be a rocket car.
06-03-2018, 03:04 AM
One run per modification is a small sample size.
They should've tried the potato half-in and half-out of the tail pipe. Or in a bellmouth.
06-03-2018, 11:09 AM
Cyborg ECU
Totally, freebeard. In a way, their potato test might prove tha their methods are not reliable more than anything about "spherical oscillation" or whatever. In general their approach to testing needs more thought about sample size, mods, and what sorts of gains "count". I like some of their stuff a lot, but if it is not a giant gain from a single mod, Moog in particular seems unable to see the point.
06-03-2018, 11:49 AM
Yeah. I would've expected at least three runs, then a final "back to stock" set at the end to check.
You can get a variance of one or two kW in successive runs with nothing done to the motor in between.
06-05-2018, 06:02 PM
LOL I sold truck parts to potato farms for a decade. What a moving obstruction does is alter the effective length of the pipe. The timing of the reflected exhaust pulse can be used to tune the scavenging. So the trick is to move the reflection point to match the instantaneous RPM. A stainless steel potato and a linear motor.. oh bother.
06-05-2018, 11:10 PM
#9 (permalink)
If you used a mild steel potato it would weather to a nice Russet brown.
06-22-2018, 02:28 AM
#10 (permalink)
Fascinating stuff though.
