Old 01-18-2017, 05:40 AM   #31 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Hi,
the snow point at the aerodynamic dissadvantages..
ID:	21193   Click image for larger version
ID:	21194   Click image for larger version
The Following 2 Users Say Thank You to Jack-Lee For This Useful Post:
aerohead (01-21-2017), rumdog (02-10-2017)
Old 03-08-2017, 03:43 PM   #32 (permalink)
Jack-Lee's Avatar
Hi,
i build a new gadget in my car
Now i see all economic gauges i need.
Next week i would build in the new engine.. 3l/100km , no problem
The Following User Says Thank You to Jack-Lee For This Useful Post:
aerohead (03-11-2017)
Old 03-08-2017, 04:30 PM   #33 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Awesome. Do tell us about that gadget.
Old 03-13-2017, 05:25 AM   #34 (permalink)
Jack-Lee's Avatar
Hi,
thats a simple Win10 Tablet. So i could run "TunerStudio" on them, conneced via Bluetooth with my MegaSquirt ECU. The Dash are created by myself (first try), so i could see all relevant data while driving.
Cost : about 100€ and 3h(80€ Tablet, 5€ DC/DC, 10€ Bluetoothmodul for the ECU).
I buy also heat shield wrap and plates. So i could get my engine to wrap with. This reduce the coldstart-Time significantly and dont let the engine cool out between two drives.
Actual the car consumes about 3,9l/100km in City with under 15km waylength and with coldstart
aerohead (03-25-2017), oldtamiyaphile (04-01-2017)
Old 03-24-2017, 01:52 PM   #35 (permalink)
Jack-Lee's Avatar
And go on..
Old 04-01-2017, 01:42 AM   #36 (permalink)
Jack-Lee's Avatar
Hi,
i bould my own hub cap with Pizza Pans
And the fuel consumtion is now under 4l/100km also in "worst case".
Short distance, cold engine, many traffic lights, no engine turn off (because of the logging).
ID:	21421   Click image for larger version
aerohead (04-01-2017)
Old 04-01-2017, 09:43 AM   #37 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Great dash display. I will be following this thread. I have done an upper grill block and a full belly pan on my Mk IV Golf. I am getting just just less than 4l/100km or 60mpg US. I have a very steep driveway so I have not made the commitment to a boattail. I tested flat wheel covers but didn't seem to see any improvement.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
Old 01-04-2018, 05:40 PM   #38 (permalink)
Jack-Lee's Avatar
Its going on. The engine pumped up to 200Nm/125kW with 1.4l.
Weight about 620kg.
ID:	23314   Click image for larger version
ID:	23315   Click image for larger version
