Old 08-11-2016, 12:32 AM   #11 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
That's amazing mpg's ... I can't seem to do that
2000 Insight MT 106K Citrus A/C
Old 08-11-2016, 02:21 AM   #12 (permalink)
Wow!
Old 08-12-2016, 11:06 AM   #13 (permalink)
90 day: 40.51 mpg (US)
Interestingly, fuel economy doesn't seem to change between ~35mph and 50mph, though going any faster causes it to drop gradually. I wonder what the the lowest-hanging fruit is going forward. Considering that having my windows down doesn't seem to affect economy at all, at these speeds aerodynamics are probably not the biggest factor. I might want to look at something like electric A/C and water pumps (get rid of the serpentine belt) and reducing brake drag.
Old 08-13-2016, 04:59 PM   #14 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Boat tail! Do it!
Old 08-13-2016, 07:32 PM   #15 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
Impressive mileage... I guess if I want to reach 100mpg i'll have to swap cars
The Following User Says Thank You to MPGeo For This Useful Post:
ECONORAM (12-10-2016)
Old 08-14-2016, 09:51 PM   #16 (permalink)
Originally Posted by NoD~ View Post
Boat tail! Do it!
I could use some suggestions on where to start. I wonder if I should remove my rear bumper cover, or build it over it?
Old 08-15-2016, 03:32 PM   #17 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
There are several approaches. One is to simply build the new structure over the existing back end of the car, leaving most to all of the original structure in place under the boat tail. Advantage is the boat tail is solidly attached to the car, providing additional crush space in the event of a rear end collision, and you can extend the car's interior into the boat tail. Disadvantage is that it is a fairly permanent addition to your car and depending on how you design it, it could block access to the stock hatch or trunk.
Another approach is to install a Reese hitch, then build a boat tail structure supported by the hitch and stabilized by 2 additional attachment points at the upper corners. Advantage is that it can be removed from your car when not needed and can provide trunk storage space in the boat tail. Disadvantage is it blocks access to your hatch or trunk when installed.
A third approach is to buy a spare tailgate, build the boat tail structure onto this spare tailgate, then swap out the stock tailgate for the boat-tailed gate. Advantage is that, with some effort, it can be removed when not needed and it still allows access to your stock hatch or trunk when in place.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
Ecky (08-15-2016)
Old 09-28-2016, 03:48 PM   #18 (permalink)
Weather is starting to cool off. It's getting to be 50-60F during the day, so my numbers are dropping a bit.
