Old 09-10-2017, 08:59 PM   #1 (permalink)
ShinyMew's Avatar
Suzuki Swift '06 - '06 Suzuki Swift (Base)
Lightbulb Reduce your Need for Headlights: Achieving Savings with Night Vision
Humans do some strange things. Most of us find it terribly difficult to break bad habits and I can only imagine how much fuel could be collectively saved if the driving populations of each nation made small, simple changes to their transportation routine.
As we know, conventional headlights can reduce mileage by anywhere between 1-5%. In 2017, however, they're not really necessary. When dark, I have therefore started using this trick and a quality pair of Armasight night vision goggles and expect that with the fuel savings they will have paid for themselves in... well, 10-20 years.
I encourage everyone to follow suit so that it hopefully catches on with the masses. While I am often on the receiving end of a lot of honking and yelling when using this technique, that's just because the poor souls don't know any better. I haven't even crashed yet. Small savings achieved by millions of motorists would add up to commendable reductions in aggregate oil consumption by consumers.
Edit: Obviously, even though this 'technique' would provide marginally improved fuel economy, it is clearly grossly illegal and very unsafe. As the last paragraph (and the price of that particular night-vision unit) should suggest, this was a joke post. Clearly I would not make a very good comedian.
Proponent for Prevention of Cruelty to Automobiles.
The Following 3 Users Say Thank You to ShinyMew For This Useful Post:
Daschicken (09-12-2017), Ecky (09-11-2017), me and my metro (09-10-2017)
Old 09-10-2017, 10:03 PM   #2 (permalink)
If I'm using night vision while running dark the last thing I'm concerned about is fuel economy.
The Following 5 Users Say Thank You to oil pan 4 For This Useful Post:
darcane (09-11-2017), ksa8907 (09-10-2017), mcrews (09-11-2017), Mustang Dave (09-14-2017), Xist (09-11-2017)
Old 09-10-2017, 10:07 PM   #3 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Great idea! Save money while risking your life!
Old 09-11-2017, 01:50 AM   #4 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
The larger reason I have my lights on is so that others - those without night vision goggles - can see ME. I live in a city, so I can see fine without...but not a chance I'd go out there without them working.
If you want to save power/alternator drag, switch everything over to LEDs. I'm quite pleased with my ~$20 ebay LED headlights; they're about the same brightness as the power-hungry halogens but only use 1/4 the power. All bulbs converted over only pulls about 5 amps. You can go alternatorless if it's important enough.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
Daox (09-11-2017), darcane (09-11-2017)
Old 09-11-2017, 02:20 AM   #5 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
I cannot afford night vision goggles but, instead of night time lights, I use a white stick. I lean out the driver's window and stretch as far forward as I can. Must admit, it works better at city speeds than at highway speeds. I also make use of the extra light provided by other drivers flashing at me. A win win situation.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
The Following 4 Users Say Thank You to JockoT For This Useful Post:
Daschicken (09-12-2017), Ecky (09-11-2017), mchlbk (09-07-2019), RedDevil (09-11-2017)
Old 09-11-2017, 02:49 AM   #6 (permalink)
Back in the day I blew out all four headlamps upon start-up in my '59 Bel Air- they went just like old-school flashbulbs- no doubt the mechanical voltage regulator was stuck. Anyway, it was the middle of the night. Luckily I had a hand-held spotlight so I did pretty much what Jocko said except it worked just fine at highway speed.
Old 09-11-2017, 03:25 AM   #7 (permalink)
Stubby79's Avatar
"Mechanical" voltage regulator? I never paid any attention to old cars...that just sounds nutty to me!
Old 09-11-2017, 03:55 AM   #8 (permalink)
ar5boosted's Avatar
My grandfather mentioned that they had these on trains. So to control the Speed the driver would move a control-rod to the appropriate resistor needed to go at a particular speed.
If you have an alternator that spins, it's voltage will increase as rpm increases and if you went too fast obviously you would blow your globes.
I've never seen one but I'd be guessing some type of centrifugal switch to push to a higher resistor to limit current and voltage.
Yes, it's all solid state vregs now.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
Old 09-11-2017, 03:55 AM   #9 (permalink)
Three solenoids and point sets.
Old 09-11-2017, 04:17 AM   #10 (permalink)
Stubby79's Avatar
I'd think controlling the field to control output wouldn't be too terribly difficult, even mechanically.
dwl, goggles, headlights, night, night vision
