06-20-2013, 10:28 AM
#481 (permalink)
Correct: no HTML. BBcode only.
06-20-2013, 10:34 AM
#482 (permalink)
NightKnight
EDIT: Oops, didn't know that Darin had already posted the answer
No, you are right, HTML is not enabled... The trick seems to be to avoid any new lines within the table definition (or only do new lines after the table data, which Darin pointed out), as seen below
Here is some more text
You can see the difference in the code below:
HTML Code:
[table][tr][td]This[/td][td]is[/td][td]table[/td][td]#1[/td][/tr][/table]Here is some more text
[table][tr][td]This[/td][td]is[/td][td]table[/td][td]#2
[/td][/tr][/table]
[table]
[tr][td]This[/td]
[td]is[/td]
[td]table[/td]
[td]#3[/td][/tr]
[/table]
(Another trick is to use the [HTML] tags around the BB code to prevent it from being parsed)
The Following User Says Thank You to NachtRitter For This Useful Post:
06-21-2013, 02:53 AM
#483 (permalink)
Thanks for that Metro, I'll remember that trick for the future
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
10-25-2013, 12:10 PM
#484 (permalink)
Toaster Oven Driver
Can anyone tell me why I can't use the Fuel Log any more?
Every time I go to it, I'm logged out.
I log in, I get the "thank you for logging in, Real_Ale_Act. Click here if your browser does not redirect you."
And when it redirects back to the fuel log page, I'm logged out again.
ETA: yes, I'm using Firefox with NoScript, but I have allowed all this page to make sure that is not the problem.
Reason: additional detail.
10-25-2013, 02:41 PM
#485 (permalink)
As always, the first step is to delete all cookies from your browser, close all browser windows and try again.
Also try with add-ons (No Script) disabled.
10-29-2013, 12:20 PM
#486 (permalink)
This is not actually a bug but something that bugs me and can easily be fixed. I often zoom in on the page for reading and leave it there and it works great but the header is split in half since it is two images.
To keep the image together please remove the width setting in the header it fixes the issue till I zoom in about 210%.
Currently
<td class="headerbg"><div align="center"><table border="0" cellpadding="0" cellspacing="0" width="795">
To fix <td class="headerbg"><div align="center"><table border="0" cellpadding="0" cellspacing="0">
A side note that can reduce the server load some by removing the large CSS group and pushing it all into the CSS file that loads after it. That way the browser will load the .css from cache and have to download the text every time. That will save about 5.42K for each page after the first is loaded.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
The Following User Says Thank You to Phantom For This Useful Post:
10-30-2013, 01:10 PM
#487 (permalink)
Toaster Oven Driver
Cheers MetroMPG, cookie-clearing worked.
11-04-2013, 03:56 AM
#488 (permalink)
Webstore page
http://ecomodder.com/forum/ecomodder-t-shirts.php
is down, though the rest of the shop works.
11-09-2013, 10:39 AM
#489 (permalink)
Hydrogen > EV
This is a request for an added feature, could we have extra spots for instruments? For several years now, vehicles usually have come with their own, and then when we add in ours, we can only click one. It would be nice to have a "Add another" feature, or make it like a checklist.
Factory Instrument: Yes/No
SG: Yes/No
UG: Yes/No
Other (Enter here): Yes/No
12-18-2013, 01:38 PM
#490 (permalink)
Spaced out...
Not sure if it's a problem with me or the website but I can't see the MPG graph on my or others' fuel log pages and the summary thing on the bottom is hit or miss as well. Tried to view them on 2 different computers using Firefox and IE with no luck...
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
