Old 05-19-2018, 12:03 PM   #21 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Originally Posted by ME_Andy View Post
That Insight is equipped with a CVT transmission, and the early CVTs were prone to failure oftentimes before 200K miles. Plus, their fuel economy is rated about 10% lower than the manual.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 05-19-2018, 12:05 PM   #22 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
IDK, Civics are perky little cars to drive. I could see myself in another 6th gen Civic when this one dies, or another Honda product...maybe an Integra? RSX? TSX? Most anything else is going to feel dead in its feet after driving a Civic. If it's not too serious a repair, I might just chase after it.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 05-19-2018, 12:16 PM   #23 (permalink)
That Craigslist link was to a CVT Gen 1 Insight..
Civics are great cars..
Old 05-19-2018, 07:24 PM   #24 (permalink)
90 day: 29.44 mpg (US)
I picked up another Autozone tester, still have the O'Reilly one, and bought one from Harbor Freight. That makes four testers. Should I have tested more?
I only have four cylinders!
I recorded video of each gauge on each attempt, went back, and noted the PSI each time that I stopped cranking, but three of the gauges dropped to zero before I saw them.
The only obvious difference between my Autozone tester and the one that I can still return is that the plastic face is pushed in. Does it make a difference? I am sure that it makes a difference that sometimes they never seemed tight. With each of them I hand-tightened and then tried five more times to tighten it further. From time to time the Autozone testers never tightened, I rotated it another fifty times and it was still loose. So, their data is garbage, but have it anyway! I do not have any idea why there are blank spaces. Have it anyway!
Cylinder Permanent loaner O'Reilly's Temporary loaner Harbor Freight
1 84 85 50 105
2 80 79 25 109
3 80 85 20 102
4 124 99 0 110
I tried to make a graph of the data, but Excel disappeared twice before I got very far.
I also rented the combustion gas tester. The fluid turned green, but the tester jumped into my lap and peed on me when I reached for my phone to take a picture. I tried again, with the exact same results.
A novice might assume that the Harbor Freight gauge is the same one as the O'Reilly one, but that is ridiculous! The Harbor Freight one says "Pittsburgh" and the O'Reilly one says "Totally not Harbor Freight, I swear!"
The hoses are similar (far more flexible than the Autozone ones, which was nice), but the HF one was significantly longer--annoyingly so. Oh well.
The cases were different and Harbor Freight had far more adapters. Curiously, the permanent connector was the only one to not fit my engine. I put Lock-Tight on the connector so it did not twist off in my block.
The data suggests each tester but mine was in tight enough.
Old 05-20-2018, 05:28 AM   #25 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
That engine looks healthy to me. Yea, it's worn as ****, but the compression numbers aren't even 10% off. That's pretty damn consistent.
Old 05-20-2018, 03:01 PM   #26 (permalink)
EcoModding Lurcher
mort's Avatar
But way back at the beginning you said...
I stopped at the first place that sold distilled water and popped my hood. Nothing looked too bad. The radiator was cool to the touch.
What?!
I popped the cap and it was low, so I added water, but it gushed out the top.
Why distilled water?
Cool radiator suggests broken thermostat.
-mort
Old 05-20-2018, 03:59 PM   #27 (permalink)
Cool radiator suggests no fluid because all of it gushed out. I replaced the thermostat last year with one from a dealership. Yesterday I replaced the radiator because it was cracked. Radiator now warms up when I drive it, indicating the thermostat works.
Ecky (05-21-2018)
