Old 07-29-2015, 02:13 PM   #1 (permalink)
A sportscar that does 50mpg imperial, 41 mpg US
Thought you guys might like this, the new Miata Skyactiv compared to the previous versions is rather frugal whilst being good fun at the same time as expected. This was the 2.0L version the 1.5L is better still.
These are imperial figures, but a 91 mile trip with the cruise set at 69mph = 49mpg (imp) even giving it a good thrashing still netted 34mpg which was a surprise.
Black Lupo 3L 1.2tdi Manual converted the windsurfing bus!
Kermit the Lupo 3L 1.2 Tdi with a current mpg record of 114mpg (imperial) Now sold
G1 JDM Insight I hate the ride but love the quirkiness
Old 07-29-2015, 02:22 PM   #2 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Could we add imperial to the title? Still nice to see, but 41 MPG is a bit off from 49 imperial...
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Last edited by UltArc; 07-29-2015 at 03:19 PM.. Reason: quick numbers in post vs math
Old 07-29-2015, 02:36 PM   #3 (permalink)
I'd like to see a Miata with taller gearing and a SkyActiv-D.
Old 07-29-2015, 05:20 PM   #4 (permalink)
...beats walking...
How about a 'driver-switchable' dual-ratio final drive ratio?!?
Or, simply another gear (long-legged) in the transmission?
Old 07-29-2015, 06:12 PM   #5 (permalink)
Hydrogen > EV
Aren't these 6 speeds now? It's not like it would be pegging 5th anywhere, why not keep a tall 6th?
Best Tanks:
Old 07-29-2015, 06:38 PM   #6 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Thank you OP for posting. It's encouraging to see a car that is fun to drive and fuel efficient.
I've been wondering the same thing and while discussing with friends we seem to have come to a conclusion of sorts that works in our minds but could be completely wrong to the auto makers. What we think is that the OEM kind of picks what 1st gear should be for the expected performance of the vehicle, after that, the following gear ratios are then, basically, chosen for them given a certain RPM drop/shift that the OEM deems "acceptable" for the common driver to be able to handle. Considering that most people who drive 5spd transmissions these days are just a little less clueless than their ATX counterparts, the OEM needs to plan transmission gears that even a monkey could handle. Having a highway only gear could confuse people since they are taught to keep shifting until you run out of gears and if you design a big drop in RPM between 5th and 6th, it could lead to people complaining out poor performance in 6th (lugs when 6th is engaged, need to downshift to pass etc). So they leave the recipe alone, gear it short so people think the car is fast, keep 1,000RPM drop/shift so they can't stall it or lug it, and just let the engine whine at whatever RPM 70mph in 6th results in.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 07-30-2015, 10:20 PM   #7 (permalink)
That would be interesting, but also increases the overall friction losses thru the driveline.
Just one gear spreaded too far from the other ones? Doesn't seem to make so much sense.
