01-25-2015, 12:54 AM
#41 (permalink)
Thanks for posting this
01-25-2015, 02:56 AM
#42 (permalink)
If they made them 250cc, they're no longer interesting, as they have to compete against the Honda Rebel, Suzuki TU250x and Yamaha Vstar250.
with their 150cc they had a unique bike. The 250s are less economical in the city.
granted, with gas prices going down it makes sense, but give me that 150cc over a 250 anytime!
01-25-2015, 06:04 PM
#43 (permalink)
The Sym 250 is a sport bike for $3800 and the nearest dealer to Sendler and I is in the Buffalo area. The Wolf 150 (90 mpg rated) is a retro style similar to the Suzuki TU250 and is listed on the Sym site under the scooter section. The Honda Rebel and Vstar are cruiser style bikes. Like your favorite screwdriver, the motorcycle should fit your hand and your travel needs. With proper streamlining a smaller bike can hold its' own at highway speeds.
01-25-2015, 08:45 PM
#44 (permalink)
After riding my PCX150 for the last year and a half I'm starting to warm up to the idea of a foot forward riding position. Time for Honda to do an update of the Rebel using the 300 platform components to update to fuel injection, water cooled, tubeless tires, instruments, larger tank, ect. Same price, $4,100. Then this bike with it's lay back position and ultra low seat height would become the go to foundation for a modern streamliner that could average 150 mpgUS lifetime and keep all your cargo dry.
01-28-2015, 12:21 PM
#45 (permalink)
Whether the rider leans forward or to the rear the idea is to reduce the height and frontal area. The only concern with a rear leaning arrangement on a scooter is F/R weight distribution. Just make sure the tail is long enough to keep the center of pressure behind the center of gravity and enough down force on the front tire for good handling.
The Sym 250 was rated at 96 mpg and the 150 rated at 90 mpg likely due to the fairing. In project after project the results seem to be +50% improvement from streamlining and 50% from hypermiling.
01-28-2015, 12:53 PM
#46 (permalink)
Scooters are already feet forward and low but the cvt drive gives up some efficiency in the rubber belt and variable pulleys compared to a chain. Standard bikes such as the CBR250R or Ninja250 dictate a head forward lean if you want to reduce frontal area and height of the side CoP. Alan has chopped the frame and added length to the swing arm of his second Ninja to get a lower, feet forward position. Moving back on the Ninja always involves reworking all of the cables and lines and shift linkages. An updated Rebel300 would be an excellent starting point for a high efficiency streamliner with it's already low seat and laid back foot forward ergos and wouldn't need any of these advanced mods.
A motorcycle has two wheels stuck to the ground. It is not an arrow and doesn't gain it's stability from having the CoP behind the CG. In fact, the optimal place for any side lift from crosswinds to act is centered on the steering head as proven in an experiment where a team tied a string to a bicycle at various places and found that when tied to the steering head, the bike perfectly self corrected for any reasonable side loads without any rider input. When tied to the seat post or rear of the luggage rack, the bike was easy to pull off course.
I would have to see a log on any Sym 250 to believe a standard rating of over 90 mpgUS.
01-29-2015, 12:32 AM
#47 (permalink)
Could you get some info on the bicycle experiment? I'd like to try it myself.
01-29-2015, 05:35 AM
#48 (permalink)
I don't know if I ever posted the link to the experiment. It was first discussed in the "Motorcycle aerodynamics" thread.
http://ecomodder.com/forum/440784-post225.html
The Following User Says Thank You to sendler For This Useful Post:
01-29-2015, 10:26 AM
#49 (permalink)
I checked the Wikipedia links but the string experiment was not mentioned. I want to carefully research all of this as I design fairings for bikes and scooters. While I have considerable training and experience on bicycles, I rely on others for road motorcycle data.
01-29-2015, 10:43 AM
#50 (permalink)
The link may be burried elsewhere in the motorcycle aerodynamcs thread. It was done on a regular bicycle by a group doing research on HPV streamliners.
