Old 12-09-2012, 04:12 PM   #11 (permalink)
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
w0w.
Lets hope the brunt of that isn't the drivetrain!
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
Old 12-10-2012, 12:57 AM   #12 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Subscribed.
Old 12-11-2012, 10:48 PM   #13 (permalink)
Originally Posted by nbleak21 View Post
w0w.
A quick search shows the following:
Insight engine weight = ~128 lbs
Insight transmission = ~50 lbs
Insight hybrid system = ~95 lbs
Total drive train = 273 lbs
Beetle engine weight = ~360 lbs
Beetle transmission = ~80 lbs
Total drive train = 440 lbs
Delta = 167 lbs... or around 9% of the entire vehicle weight.
I'll be moving the battery to the rear hatch to help with weight distribution. Unfortunately I'm going to have to use a battery with a higher capacity to start the high compression diesel so that will add more weight...
I'm guessing the car will be ~200-250 lbs heavier than a stock Insight with the additional bracing and other mods necessary to pull this off.
P.S. Beetlejuice is broken. It developed a loud clunk and a bad shudder engaging 1st gear... I suspect the dual mass flywheel has given up the ghost due to me beating on it.
Old 12-13-2012, 10:04 PM   #14 (permalink)
Garages and frickin' laser beams!
Click to view my latest post below
www.hondatdi.com
Starting to get geeky now...
Old 12-26-2012, 01:41 AM   #15 (permalink)
Originally Posted by gtmotor View Post
I'm obviously not condoning skipping out on emissions regulations (especially on a forum like this!!) but there are times when they simply don't make sense.
Sometimes the emissions regulations seem too dumb to be true. EPA witch-hunting against Diesels is one of those pointless aspects of the current "environmental" laws.
workaround ideas to discuss among friends: Arguments against EPA witch-hunting regarding Diesels without mandatory emissions equipment
Old 12-26-2012, 06:57 PM   #16 (permalink)
So, I'm debating using a Civic hatchback (EG) instead of an Insight for this project. I can't find a reasonably priced Insight around here (people want insane money for these right now).
Pros for the Civic:
- Easier swap
- Can carry 4-5 people if needed
- Has more room to carry junk
- Parts more readily available
Cons for the Civic:
- Heavier
- Less aerodynamic
- Not as interesting
Should I keep holding out for an Insight or just buy one of the dozens of Civic hatchbacks on Craigslist?
Old 12-26-2012, 07:03 PM   #17 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Looking for salvage title vehicles?
Old 12-26-2012, 07:07 PM   #18 (permalink)
I was trying to avoid it but I may pick up one depending on why it was salvaged. Flood or theft history would be fine, crash damage will probably not be fine.
Old 12-26-2012, 07:29 PM   #19 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
How about a TDI into a 2nd gen CRX swap? Lots of CRX shells for sale on CL.
http://phoenix.craigslist.org/search...inAsk=&maxAsk=
- Tony
Old 12-26-2012, 07:33 PM   #20 (permalink)
A diesel CRX would be fun.
Otherwise, hold out for an Insight. Tony (especially!) and I have proven they're available out there for cheap if you're willing to hunt (and be patient).
