02-13-2018, 08:47 AM
#271 (permalink)
Do you even BBCode?
Woah. ..Please see http://ecomodder.com/forum/showthrea...html#post78632Vehicle | Tesla | Chevy Bolt | Nissan Leaf |
Capacity | 85 kWh | 60 kWh | 40 kWh |
HP hours | 3,740 | 2,640 | 1,760 |
Weight | 1,200 | 959 | 560 |
Lbs HP Hr | 10.52 | 11.92 | 11.06 |
HP hr/lb | 3.125 | 2.75 | 3.14 |
Range | 265 | 239 | 150 |
HP hr/mi | 14.11 | 11.04 | 11.73 |
Cost per mi | 4.36 | 3.34 | 3.35 |
Vehicle | 32 mpg Car | 18 mpg PU |
Capacity | 590 kWh | 852 kWh |
HP hours | 25,960 | 37,488 HP hours |
Weight | 113 | 164 lbs |
Lbs HP Hr | .142 | .142 lbs |
HP hr/lb | 229 | 229 HP hr per lb |
Range | 576 | 468 miles |
HP hr/mi | 45.07 | 80.1 HP hrs per mi |
Cost per mi | 7.18 | 12.7 cents per mi |
The Following 2 Users Say Thank You to Xist For This Useful Post:
02-13-2018, 12:44 PM
#272 (permalink)
Thanks. What had you reading a 10 -year-old thread anyway?
TestDrive's post at Permalink #20 is pretty impressive.
I consider this the most boring type of censorship.
The banality of ...white space.
02-13-2018, 01:57 PM
#273 (permalink)
I honestly do not have any idea how I get where I am sometimes. I need an eye drive. Perhaps I had one, but I decided it was better to forget.
Why do people ask for how long I have had a memory problem?
02-14-2018, 11:57 AM
#274 (permalink)
Thalmaturge
Originally Posted by Xist
Can you just paste tab separated values here in the CODE tags?
Code:
Col 1 Col 2 Col 3 Col 4
Row 1 11 12 13 14
Row 2 21 22 23 24
Row 3 31 32 33 34
Row 4 41 42 43 44
Edit: Yes, you can.
02-14-2018, 01:37 PM
#275 (permalink)
Thanks, but i would have no clue how to use the function you just described. Could you copy and repost it formated for us?
02-14-2018, 03:12 PM
#276 (permalink)
Thalmaturge
You just have ubb tags before/after your whole table like code and /code but with brackets around them (just like the quote tag) that give you a monospace font and spaces and tabs are maintained.
Then you can do what i did there and paste data straight from Excel/LibreOffice and it will come out as a table. Likewise copying a web table should go right in as a table too.
Code:
Vehicle Tesla Chevy Bolt Nissan Leaf
Capacity 85 kWh 60 kWh 40 kWh
HP hours 3,740 2,640 1,760
Weight 1,200 959 560
Lbs HP Hr 10.52 11.92 11.06
HP hr/lb 3.125 2.75 3.14
Range 265 239 150
HP hr/mi 14.11 11.04 11.73
Cost per mi 4.36 3.34 3.35
The only problem you'll run into is if a column has values that exceed the tab stop, data will run into the next column and things will get shuffled, as above.
02-14-2018, 03:32 PM
#277 (permalink)
02-16-2018, 12:47 PM
#278 (permalink)
Bloomberg is posting a Model 3 tracker. Up to 1,000/ week.
https://www.bloomberg.com/graphics/2018-tesla-tracker/
The Following 2 Users Say Thank You to sendler For This Useful Post:
02-16-2018, 05:13 PM
#279 (permalink)
Originally Posted by sendler
That tracker shows an interesting trend.
By each months end the number of Model 3's produced doubles.
If that trend persists for 30 years there will be more Model 3's than atoms in the entire universe.
(they'd surpass the total world car production within a year and a half)
02-18-2018, 10:28 AM
#280 (permalink)
Thalmaturge
In case it hasn't been posted here, the mix of materials in a model 3 body. Broken down into mild steel, high strength steel, ultra high strength steel, and aluminum.
https://electrek.co/2017/08/22/tesla...ody-alloy-mix/
Lots more pics in the article.
The Following 2 Users Say Thank You to samwichse For This Useful Post:
