Go Back   EcoModder Forum > AltModding > Saving@Home
Old 02-12-2017, 01:12 PM   #21 (permalink)
Two weels Zero sparkplugs
Originally Posted by MobilOne View Post
Water heater temp: A long time ago, 1970's or 80's, Ohio State Univ found that a water heater temp below 120 degrees f. fostered the growth of Legionaires disease germs. So keep it at 120 deg or a little higher.
Even though this is an older post I'd like to add that this isn't necessary for a tankless heater.
Old 02-16-2017, 11:07 PM   #22 (permalink)
Heilopower
Platinum Ghost - '14 Ford Fusion SE
90 day: 27.51 mpg (US)
One trick to keep the water a bit hotter before it reaches the shower head is to spray expanding insulation foam into the wall behind the shower through a tine hole. Will keep the water in the pipe, concealed by the wall, much warmer. Made a noticeable difference in my un-insulated interior wall behind the shower. Only wish I had thought of the idea sooner. Now I may also try insulating the pipe from the wall to the shower head.
Old 02-17-2017, 07:57 AM   #23 (permalink)
This is a bit less drastic than purring walls shut and also works quite good:
ROI should be only a few months.
You also can install a heat transfer drain:
It's a bit harder to retrofit in an existing bathroom but if you're renovating it is a must have, really saves a lot.
Originally Posted by earl92 View Post
just use heat blocking windows to make cool envoirment.
Replacing the windows can be harder to pull of in a flat but some heat blocking foil goes a long way if you live in a warm environment.
