Old 09-26-2014, 06:43 PM   #1 (permalink)
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Question Which type of engine oil is best?
I've been using Castrol GTX 5w-30 pretty much the entire span of ownership.
I have been curious about Mobil-1 oil...especially a specific type titled "Advanced Fuel Economy".
Has anyone tried this and seen results? Is this a good line of engine oil? What type and/or brands do you recommend and why?
Thanks!
Happy Hypermiling!
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
The Following User Says Thank You to SilverCrown9701 For This Useful Post:
Cd (02-23-2015)
Old 09-26-2014, 07:57 PM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
As far as protection goes, oil is oil. As long as you keep it clean and change when it does get dirty you'll be just fine.
For f/e, synthetic has superior viscosity characteristics therefor less resistance from pumping it around the engine.
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
SilverCrown9701 (09-28-2014), sqidd (09-27-2014)
Old 09-26-2014, 08:11 PM   #3 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
Synthetic oils also have superior resistance to heat breakdown compared with non-synthetic oils.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
Old 09-26-2014, 08:26 PM   #4 (permalink)
Not all Mobile One oils are the same.
They are allowed to call it synthetic if the base has a certain percentage
Mobil 1 is not a true synthetic.
Mobil 1™ Extended Performance is 100% synthetic.
I'm not sure about "Advanced Fuel Economy".
You can learn all you ever wanted to know about oil and lubricants here.
Bob Is The Oil Guy | The Internet's Number One Motor Oil Site
The Following 2 Users Say Thank You to redneck For This Useful Post:
Fat Charlie (02-23-2015), SilverCrown9701 (09-28-2014)
Old 09-26-2014, 09:43 PM   #5 (permalink)
The best oil to use is the one recommended by your owners manual and dictated by the temperature climate you are driving in.
The Following 2 Users Say Thank You to Cobb For This Useful Post:
ME_Andy (05-11-2015), SilverCrown9701 (09-28-2014)
Old 09-26-2014, 09:58 PM   #6 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Dyno tests have shown a 2.5% improvement to power output, so at a guess economy would improve a similar amount (at peak power). Any on the road gains will never be measurable.
I need to use special 'low ash' oil in my TDI. I'm thinking I don't want 'ash' in my other 'fully' synthetic oil cars either.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Old 09-27-2014, 01:18 AM   #7 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
The FSM for my dad's car recommends a 20W50 for California summers. Nope. Not happening. I'm more likely to run a 5W30 in it so oil is flowing sooner.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following 2 Users Say Thank You to H-Man For This Useful Post:
Joggernot (04-03-2016), SilverCrown9701 (09-28-2014)
Old 09-27-2014, 04:11 PM   #8 (permalink)
Breeze - '97 Plymouth Breeze
90 day: 23.1 mpg (US)
In terms of this site, Mobil 1 AFE actually isn't a bad oil, but the science behind it all gets fairly complicated. The best oil for fuel economy is the thinnest oil you can run at operating temperature, with the thinnest profile at cold temperatures.
These are your 0W-20, 0W-30 oils for the most part since the first number just dictates how easily pumped the oil is when cold, the lower the better. Does your call call for 5W-30? Try 0W-30 if you can find it. 5W-20? Try 0W-20. If it says either 5W-30 or 5W-20, try 0W-20, since its thinner at operating temp.
And realistically, you can use 0W-20 or 5W-20 in a car made for 5W-30. My car only specifies 5W-30 but later models just "suddenly" started suggesting 5W-20. The difference in oil thickness isn't a lot between 20 and 30 weight - most worn out 30 weights are the same as a 20 anyhow. So if you're particularly anal about getting economy and want the (maybe) %0.5-%1 improvement and don't mind being a little on the darkside if your manual doesn't say you can, run a 20.
But beyond that the best oil is complicated and based on cost and a variety of factors. I run Mobil 1 Delvac Elite 222 - a diesel motor oil in my car. Why? Well its a 0W-30 first of all and designed for easy starting of big diesel trucks in cold Canada winters, and in a car its fantastic. Second its loaded with an older zinc-based antiwear additive that they phased out on gasoline cars, so I get free extra wear protection. It also helps make me feel good that its a "true" synthetic but don't let that scare you. A lot of people overstate the difference between "group III" and "group IV" (or PAO synthetics), the latter being the only ones truly "man made". It also helps that being a diesel oil, they expect you to buy something like 15 liters of it and its marketed way, way differently -- it was cheaper at a distributor for Mobil then I can get Mobil 1 AFE, even on sale!
But it didn't stop me from buying a jug of Quaker State 0W-20 to try next winter. Why? Well it was really cheap and I wanted a 0W-20 to run in the car, something you can't get in diesel oils.
About the only major argument you can make is some oils are "a little better" or tailored a little more to specific situations. For the layperson? Oil is oil. Just buy the right oil. The number of people running 10W-30 or 15W-40 for absolutely no reason is insanely high. Or even worse, having people say you need oil "stabilizer", thicker oil for driving to Church on a Sunday, or even people saying you need a 10W-30 for winter -- the confusing rederick you hear in the oil aisle is frustrating.
Check your manual, buy the thinnest weight you can run, and buy a decent oil that meets the SAE requirements your manual calls for, and be happy.
If you have the choice of running a synthetic, you can go to 0W-20 or 0W-30 and *maybe* get a free half an MPG, but it really won't be measurable. The car will definitely be happier starting when cold and might start easier if it gets properly cold (like -30 cold) where you live.
The only benefit for running a synthetic after that is extending your oil change interval, which may or may not void your warranty. If you're changing a synthetic out every 3000 miles you're wasting money, period, use a regular oil. In my case the car calls for a 3000 mile oil change, but I run it out to 7500 miles on the Delvac Elite 222 I run.
And for the record, I just love saying I only run "Delvac Elite 222". It sounds awesome and usually generates nothing but "car guys" telling me it doesn't exist or its going to ruin my car and how I should run Royal Purple or some overpriced garbage.
The Following User Says Thank You to RiceCake For This Useful Post:
Old 09-27-2014, 04:43 PM   #9 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
When I bought the Turtle, the guy had just changed the oil with Amsoil 0w20.
Supposedly it's good oil, but I haven't really looked into it. In a couple thousand miles I'll get around to seeing what the change out interval is.
The Following User Says Thank You to cowmeat For This Useful Post:
Old 09-27-2014, 04:58 PM   #10 (permalink)
Amsoil is the best quality oil hands down
The Following User Says Thank You to ksa8907 For This Useful Post:
