Old 03-29-2015, 08:24 PM   #1 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Ultragauge + Scangauge on an obdii y cable
I just wanted to put this here to save another the trail and error I just went through.
I cut off a second obdii port from another civic and spliced it to my existing one.
I confirmed that on a 1997 Civic you CANNOT run both gauges at the same time.
I have read that others were successful doing this but it definitely doesn't work with this ecu.
I'm pretty certain it's due to the K-line ISO 9141 protocol this car uses.
I bet if your car uses a can-bus it would work.
1998 LX with a full HX swap + VX transaxle.
The Following 2 Users Say Thank You to firehawk618 For This Useful Post:
Daox (03-29-2015), mikeyjd (03-29-2015)
