Old 03-26-2017, 07:25 AM   #41 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Now i will start experimenting with my injector.
What volumes should i be looking for. 2.4 l/h will probably be the cruising average.
And do I even want it to be able to keep up at full load?
Old 03-26-2017, 07:50 AM   #42 (permalink)
teoman's Avatar
A3 - '12 Audi A3
The fuel injectors on my car change from
6Hz Idle
16 Hz 2000 Rpm
50 Hz 6000 Rpm
This is very low, i will try to get my PWM as low as possible to minimize the injector cycles.
Old 03-26-2017, 09:00 AM   #43 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I am typing my injector input and output diameters here.
Output:
Metal part: 11.11 mm
Oring: 14.5 mm
Input:
Metal Part: 13.5 mm
Oring: 14.5 mm
Groove where oring sits: 8mm
If anyone has any ideas on what type of hose i should attach to this, do let me know.
From what I remember, the orings should be compressed %20.
The oring has a thickness of 3.25mm which should compress to 2.6 mm.
8+ 2.6 *2 = 13.2 mm.
So that should more or less be the internal diameter of what I will connect to it.
Old 04-01-2017, 08:41 AM   #44 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I am looking at installing the system at the moment.
Being a V6, i have 2 exhaust manifolds. Would adding this apparatus to one side and removing some heat from it have any effect on the engine? Will it cause any issues with imbalance?
Old 04-01-2017, 08:52 AM   #45 (permalink)
Not sure if it might lead to a harsher operation of the engine when you install it only at one side, but eventually it might allow you to compare the differences in temperature and eventually other issues before you go for it on all the cylinders.
Old 04-01-2017, 08:59 AM   #46 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I live in a country where auto work costs an arm and a leg. Especially spare parts. So would prefer not to find out the hard way
Ill try to design the distillery on to the other side.
Old 04-05-2017, 07:16 PM   #47 (permalink)
So do I.
BTW have you ever heard about Bi-Phase Technologies? This company develops liquid-phase LPG fuel systems for engines with conventional MPFI, maybe it could be interesting for you.
Bi-Phase | $mart Clean Propane - Home
Old 04-06-2017, 03:57 AM   #48 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Had a look at that.
And i was always wondering why lpg was not injected in liquid phase. A phase change to gas always seemed like unnecessary work.
I think it was due to the fact that with temperature change liquid lpg expands a lot. I suppose some one came up with the idea to monitor the temp of the lpg and adjust injection time accordingly.
Old 04-06-2017, 07:37 PM   #49 (permalink)
Probably to avoid freezing the carburettor and intake manifold like it used to happen with some makeshift conversions in my country.
Old 04-08-2017, 10:46 AM   #50 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Chip Foose was talking about building a custom small block engine that would have liquid propane direct injection the plan was to use the expansion to create false boost. The system was estimated at equivalent to 3psi and 0% parasitic loss
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
