Old 03-07-2008, 09:18 PM   #11 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
I can think of a lot of places where you could add these to the trailing edge of something on a car to improve drag CF.
- You could add a lip to the trailing edge of a hatch-back and it may work like/better then our standard VGs.
- You could add it to the trailing endge of the lips of the front bumper that some cars have
- You could add it to the trailing edge of side view mirrors
You might be able to put them in any of the places you might put normal VGs and it may have the same effect...
Old 03-07-2008, 10:24 PM   #12 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
darn these blades are obsolete.
Old 03-07-2008, 11:56 PM   #13 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Nice thread... I think I included tubercles in my mega write up... but I'm with donee on this one
I do not see a real obvious eco-modder applications. But it certainly would be a great thing for these big wings they put on ricer cars. They could generate more downforce for less drag.
These are useful when you have a sharp leading edge on a plane parallel(ish) to flow... Like a turbine blade, whale fin etc. Ideally, one shouldn't have pointy bits, planar leading edges etc.
The working fluid is different as well. Somewhere in my fluid mechanics texts I have the method to calculate changes in fluid/speed/power/etc in order to do scale modeling. Buckingham Pi method IIRC
Reynolds number Make them equivalent by changing the density property, then adjusting velocity to keep a constant ratio...
Anyone know the average velocity of a whale with tubercles? Or better yet, the relative ocean velocity of a whale with tubercles?
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 03-10-2008, 01:55 PM   #14 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
"What do you mean? An English whale or an African whale?"
"Wha...oh...well...I don't know! AAIIEEE!" (Whoosh!)
The Following User Says Thank You to elhigh For This Useful Post:
Xist (09-12-2017)
Old 03-10-2008, 07:33 PM   #15 (permalink)
tubercles and testoserone?
Fun read! Guess we'll all see if it goes in the marketplace.Ease of manufacture may be an issue.Thats some very sophisticated architecture. Pressure and velocity distribution could affect dynamic balance,and resonance ( flutter ) may affect structural integrity with high velocity applications, as there are so many local areas of impact,channeling,redistribution and discontinuities of aft-trailing -edge flow .Super-turbulence!Whales can articulate their flippers while turning,changing angle of attack at will as they pirouette in the water.The fluke of the whale is responsible for propulsion.I'd be more impressed if the tubercles were present in the fluke where the real power is laid down .Since whales communicate at extremely low frequency,could it be that the tubercles are "heard" by other would-be mating-age male whales and fertile in-season females,as tail-feathers are "seen" on the male peacock? Yep,I'm losing it alright!
Old 10-02-2008, 01:33 PM   #16 (permalink)
04CLK500 - '04 Mercedes Benz CLK 500
90 day: 24.47 mpg (US)
BigFord F-450 - '01 Ford F-450 XLT Cab/Chasis
Last 3: 18 mpg (US)
Airtab
This company has supplied this RV manufacturers, seem to be doing well with Semi's and Vette's too.
Or was this known already?
-Eric
Old 10-02-2008, 03:06 PM   #17 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by EricTheRed View Post
Airtab
-Eric
A lot of people have been discussing Airtabs and a few have tested them on cars or pickups. Just type Airtab into the search box at the top of the page and you should get about 17 hits.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 10-06-2008, 11:23 PM   #18 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
What if the whale is carrying coconuts?
You silly English-types! I faht in your genellal dilection!
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
Xist (09-12-2017)
Old 11-08-2008, 06:26 AM   #19 (permalink)
Interesting idea. I'm thinking: canard configuration airplane with serrated edge main wing for stall resistance. General goal is low speed handling, agility and STOL characteristics. Need to do some more research though.
Old 11-08-2008, 08:54 AM   #20 (permalink)
Are you thinking about RC or Full Scale?
I think one of my low-speed DIY RC SPAD planes might be a good test-bed for a saw-tooth LE.
Since this type of coroplas wing has very little lift and can already fly at a pretty high AOA.
It will be very easy to tell if there is any increase in hoover and handling.
I've just got to figure out the best way to implement the saw-tooth
and get some stick time.. Hope to have a plane ready by spring time..
Cheers,
Rich
