Old 03-16-2018, 05:27 PM   #31 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I had way too much fun driving a fast car, the problem was there is generally too much traffic to make use of any of the power.
I guess we should all drive 400hp full size trucks for simple commuting, clearly the best option we have.
Old 03-16-2018, 05:41 PM   #32 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
100% its limited because it will thermal throttle over 90 mph. Prius had inverter heat issues so i assume its the same for most ev's as well since they are designed for efficiency not racing (so far). But that whole horsepower thing is relative. My 2010 prius doesnt have 150hp and this car will do 120 mph and ive maintained 100 mph for three hours going across empty Arkansas Interstates. (Fayetteville to Jonesboro; 3 bours vs 4.5 hr) I think speed averaged was closer to 90 mph and it averaged 31 mpg.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 03-16-2018, 06:30 PM   #33 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
It's never been about the economics for me. It's all about reducing fossil fuel use and demand. That's why I started driving diesels and making biodiesel back in 2003, and what do you know? It was cheaper than fueling a gasoline or diesel car.
I'm grown up now though, or maybe electric technology is, and I'm ready to get a Bolt myself (or a Leaf). I have further reduced my energy use by moving closer to my workplace (from 21 miles to 5), so the reduced range of an electric does not affect my driving at all.
Electric is the optimistic future and I embrace it.
I'm not coasting, I'm shifting slowly.
The Following User Says Thank You to UFO For This Useful Post:
NeilBlanchard (03-17-2018)
Old 03-17-2018, 09:08 AM   #34 (permalink)
Want to drive fast? Reserve a Model 3. Unless 140MPH is enough for ya'. Then you should get the Roadster 2 - 250MPH+
Old 03-17-2018, 03:12 PM   #35 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by hayden55 View Post
Chevy limited all the output on their EVs because the batteries typically get really warm with high amperage outputs so no high speeds homies, and people complained that the cars ate tires since they had too much torque *see the laughable 2011 Chevy Spark with 400lb-ft of torque lol*
I have one of those "laughable" Spark EVs (Made from 2014 to 2016) Yes, it has 400 lb-ft of torque at 0 RPM and will spin the tires at will. It is the hot hatch of the EV world. I was attempting to merge this week and was spinning the tires at 45 mph at partial throttle. That said it isn't the tire spinning that kills the tires on the Spark it is the absolutely horrible tires GM chose to install. I was down to the wear limits on all 4 tires in 6000 miles. Today I have performance all-season which help with the tire spin and lack of grip but knocked 10% off the range. 6K miles later the new tires still look practically new.
All in all it is a fantastic car for my use. I drive it 50 miles round trip to work and around town (Dinner, shopping, etc). Even at only 82 miles of EPA range that it works fine for my daily use. When we go out of town hiking, backpacking, skiing, etc we take my wife's Prius.
Charging at work (free) or home is very convenient. It doesn't matter that it takes hours to charge because I'm either working or sleeping. There is no maintenance besides changing the cabin air filter every 30K miles and changing the coolant at 120K miles.
Economics. The lease ($0 down 39 months) is $100 a month. Insurance is $600 per year ($100 more than a 10 year old Prius). If I had to pay for the electricity it would cost about 2.6 cents per mile. (Gas for the Prius is 5.6 cents per mile.) So running costs are half the cost of driving a Prius but the Spark is fun to drive while the Prius is not)
Battery replacement: It's a lease so I don't care. That said, I wouldn't buy my Spark because it was a compliance car that GM built 2000 a year to fulfill the CARB EV mandate. I don't expect to have parts available in the future and a replacement battery pack is more than $20K. On the flip side Nissan has sold hundreds of thousands of LEAFs and an upgraded battery pack is only $5500. I suspect in 10 to 15 years if Chevy Bolts need battery packs they will also be reasonable. I also suspect the aftermarket will have remanufactured packs available like those offered for the Prius.
To sum it up, EVs make sense for city dwellers that can charge at home or work and have more than one car. The good news is that is most of the US population.
Old 03-17-2018, 10:15 PM   #36 (permalink)
Because an ev doesn't have drivetrain and gearing losses.
Whatever the motor produces, is pretty much whatever is at the wheels,minus rolling resistance (like from deflated tires).
A 4 stroke of 150HP usually only gives 135HPmax at the wheels, times the gear ratio.
Eg: if you have an overdrive gear ratio of 0,97:1 as 4th gear, being closest to a direction drive, and 134HP at the wheels with a direction drive, your car is only getting the performance of a 130HP at best. In 6th gear, if your gear ratio is 0.75:1, you're essentially only getting 97.5 HP in final gear, from a car which engine gives 150HP.
Old 03-17-2018, 11:04 PM   #37 (permalink)
Yes I understand the concept of what you mean as I'm engineering (gear reduction and efficiency), but your not gonna need more than 20-30 hp to maintain 70. Horsepower to overcome drag at 80 mph would be around 40% more which still would only be like 1/3 throttle.
Also EVs still have gear loss its just minimized since they only have a final drive system forgoing the transmission unit. So no free cake here.
Old 03-17-2018, 11:26 PM   #38 (permalink)
I have one of those "laughable" Spark EVs (Made from 2014 to 2016) Yes, it has 400 lb-ft of torque at 0 RPM and will spin the tires at will. It is the hot hatch of the EV world. I was attempting to merge...
Yeah laughable in more of a holy crap Chevy did a hot little setup on that car versus the standard lmao. Hilarious that it has 400lb-ft. I actually have a friend who runs a shop in Texas with a customer who bought a wrecked low mileage Spark EV he got for 3 grand and they are going to make a little time attack car out of the motor and batteries.
Old 06-14-2018, 03:20 PM   #39 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Bolt epidemic
I know THREE people locally who have bought Bolts. (I socialize above my pay grade )
And they're supply-limited around here. People are complaining they can't get them.
One bought a low kms trade-in; the other bought the first one an out-of-town dealer got without even driving it; the most recent buyer ordered his and had to wait 6 months for it to arrive.
I got a chance to drive one of them:
We went out for an eco-driving lesson. (Estimated remaining range increased during my demonstration drive. )
My thoughts on the car: I understand why people are interested: the incentives are hard to resist (around $10k in Ontario, I think); tons of range; the body style offers good utility; the performance is eye-opening. (You can hear the tires breaking grip when you mat the accelerator at 25 mph.)
I'll get a chance to drive one again in a few weeks - the 3rd buyer wants an eco-driving lesson too.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Ecky (06-14-2018), NeilBlanchard (06-15-2018)
Old 06-15-2018, 02:13 AM   #40 (permalink)
The bolt (or just about any EV) doesn't really work for me, just because:
  1. I don't have a clear path from my home to where my car is parked, to charge; and,
  2. I mainly drive highway miles. That means, half a battery a day, is quite taxing on such a car.
