Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-05-2014, 07:00 PM   #31 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Subscribed
Old 12-09-2014, 09:44 AM   #32 (permalink)
Here is another update.
1) Reverse air conditioner freeze up problem
F357 is having some freeze up issues with his window A/C unit that
he is using as a heat pump (reverse air conditioner).
Reverse air conditioner freeze up problem - EcoRenovator
2) Alaskan Home Energy Upgrade Project
Erich_870 is renovating his Alaskan home to reduce energy usage.
Check out what he has up his sleeve.
Alaskan Home Energy Upgrade Project - EcoRenovator
3) Preparing for Infrastructure Lapses...
AC_Hacker questions what to do, and plans for power outages.
Preparing for Infrastructure Lapses... - EcoRenovator
4) HP COP vs NG boiler $ Balance point
See how buffalobillpatrick calculates when its more cost effective
to run his heat pump versus his natural gas boiler.
HP COP vs NG boiler $ Balance point - EcoRenovator
5) Building a large shop with SIPS
Stevehull is in the process of building a 40 x 60 foot shop with
SIPs (structurally insulated panels).
Building a large shop with SIPS - EcoRenovator
Old 12-09-2014, 11:01 AM   #33 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
garage
Having an EcoRenovator garage would be helpful, for keeping track of planned and current modifications.
Old 12-09-2014, 01:21 PM   #34 (permalink)
Thanks John. It would be a really nice feature. Its actually been in the works for... well really way too long. Thanks for mentioning it though, we need a kick in the butt every once in a while.
The Following User Says Thank You to Daox For This Useful Post:
j12piprius (12-09-2014)
Old 06-22-2015, 02:16 PM   #35 (permalink)
I keep forgetting to update this thread... Ah well, here is an update:
1) My Solar Arrays
An excellent and quick history on the making of gasstingy's solar PV array.
My Solar Arrays - EcoRenovator
2) I got this tank of R134a...
Daox got a free 30lb tank of R123a and asks if it goes bad, and what can
be done with it.
I got this tank of R134a... - EcoRenovator
3) Dxgshpwh (ground source heat pump water heater)
Memphis91 has done an amazing job putting together a ground source heat
pump water heater. Seriously check this one out.
Dxgshpwh (ground source heat pump water heater) - EcoRenovator
4) Energy meter that can handle >= 5600W?
Anthezium asks about finding an elecricity meter that can handle 5600W.
energy meter that can handle >= 5600W? - EcoRenovator
5) New Mini Split
WyrTwister shows us the install of his latest mini-split.
New Mini Split - EcoRenovator
Old 09-09-2015, 11:20 AM   #36 (permalink)
1) Lennox Solar A/C
Gtojohn talks about hooking a Lennox air conditioner up to solar
panels.
Lennox Solar ac - EcoRenovator
2) 4-ton GSHP - Hydronic conversion
TechShop shows the progress on his 62' x 42' shop with 2nd floor
apartment with hydronic heated floors and planned ground source
heat pump.
4-ton GSHP - Hydronic conversion - EcoRenovator
3) New living roof
Sunspot shares his project of creating a living roof for an area
on his home.
new living roof - EcoRenovator
4) Another heat pump food dryer
Mechanic has taken the reigns and created a food dehydrator out of
an old refrigerator.
Another heat pump food dryer - EcoRenovator
5) Adding more Blown in Insulation
Geo NR Gee is considering blowing in some more attic insulation.
Adding more Blown in Insulation - EcoRenovator
Old 01-13-2016, 09:24 AM   #37 (permalink)
Another EcoRenovator update.
1) Most popular topics/threads of 2015!
What generated the most hubbub in 2015? Lots of interesting things!
Check it out:
Most popular threads of 2015! - EcoRenovator
2) Ice storm, generators and lessons learned
Stevehull shares what he learned as he went through an ice storm.
ice storm, generators and lessons learned - EcoRenovator
3) PV for a 30ft 5th wheel
Doug30293 is looking for a 400w solar PV setup for his 5th wheel.
PV for a 30ft 5th wheel (photovoltaic solar panels on RV) - EcoRenovator
4) Warmed/heated toilet seat
Oil pan 4 shares his experience with a heated toilet seat he installed.
Warmed/heated toilet seat - EcoRenovator
5) How to make the most of thermographic camera?
Piwoslaw is planning on borrowing a thermal camera and asks for tips
on how to best use it.
How to make the most of thermographic camera? - EcoRenovator
6) Anything to look for in 12V charge controllers?
Daox is looking to pick up a 12V charge controller and ask for some
advise on what to look for.
Anything to look for in 12V charge controllers? - EcoRenovator
FYI : groar's solar panels thread (EcoRenovator) groar Saving@Home 0 11-24-2008 04:19 PM
