09-19-2017, 11:25 PM
#2171 (permalink)
You know you're an ecomodder when you aeromod your *bicycle*...
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
09-20-2017, 01:09 PM
#2172 (permalink)
^ Post a thread! With pics, of course.
Alternative Transportation
09-20-2017, 01:11 PM
#2173 (permalink)
YKYAEM when...
It hurts to have to idle the engine, even though the reason it's idling is to check & set the timing to make it more efficient!
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
09-20-2017, 01:29 PM
#2174 (permalink)
So I am not the only one!
09-20-2017, 01:33 PM
#2175 (permalink)
I'm sure you're not!
And I kept putting off doing the timing becuase I refused to idle the car to warm it up prior to the task. I waited until I had to drive it somewhere first & had time afterward.
09-20-2017, 11:24 PM
#2176 (permalink)
Ahaha. But given that an idling four cylinder uses a litre an hour at worst (my SOHC, non-vvt, batch injection 4 litre six used 1.6l/hr at idle), how much fuel did you lose on subsequent drives while the engine ran inefficiently?
Now you both need to do calculus before setting your timing.
Also yes, bicycle (technically tricycle) body construction will be posted here and on bentrider. Same username
The Following User Says Thank You to BLSTIC For This Useful Post:
09-20-2017, 11:37 PM
#2177 (permalink)
YKYAEM when...you're approaching 100mpg(e) and you find it disappointing!
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
09-20-2017, 11:42 PM
#2178 (permalink)
Overtaking
Ha! Happened to me last week. And in both our cases, was likely a diesel Smart. No small feat to overtake with one of those!
On one long trip, my co-driver mentioned how he was often irritated, especially at night, by semi-trailer drivers who would charge right up behind him and then brake. I explained that they could only pass by spending a mile gaining speed, and then looking at traffic for a go/nogo. I don't always need a mile, but that's been my usual procedure too. There's some really sloppy fast drivers out there.
Reason: typo
The Following User Says Thank You to Bicycle Bob For This Useful Post:
09-21-2017, 02:25 AM
#2179 (permalink)
I don't put these jobs off. It just galls me to run the engine when I am not going anywhere. I even stick the car in gear, check it is clear to pull out, then start the engine, so that I can lift the clutch as soon as it fires up!
The Following User Says Thank You to JockoT For This Useful Post:
09-21-2017, 09:10 AM
#2180 (permalink)
Rat Racer
That's not what everyone does? Let the damn thing warm up while I'm rolling through the parking lot.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
