Go Back   EcoModder Forum > cfg83's Profile > Albums > Side Skirt
Picture 3 of 6 from Album Side Skirt
Saturn Plastic Rocker Panel front view of interior: The holes for the drop-down bolts were drilled in the "cavity" area (the round volume).  There was a problem in that if I remove the wingnut, the bolt could pop into the cavity.  I solved that by gluing pipe insulation above the bolt.  This way the bolt will stay in place.
Picture Added 10-26-2009 04:47 PM
