Go Back   EcoModder Forum > jomelmaldonado's Profile > Albums
Warm Air Intake
A closer view of the aluminum sheet and one of the 3 bolts that holds it in place. This cover forces the warm air to the intake tube extension. The...
Maximum temp achieved so far. The Scan Gauge II displaying miles per gallon (MPG), average miles per gallon (AVG), intake air temperature (cIA) and...
Overview of the engine bay, where you can see the installed warm air intake system.
It's simply made out of a PVC elbow, muffler adapters and an...
Here you can see the muffler adapters and the PVC elbow. The PVC elbow enters the air filter box through a drilled hole. It has a smaller diameter...
View of the muffler adapters and the aluminum sheet. The muffler adapters are held in place to the aluminum sheet with a coat hanger wire and a hose...
The Scan Gauge II displaying miles per gallon (MPG), average miles per gallon (AVG), intake air temperature (cIA) and coolant temperature (cWT). Both...
The Scan Gauge II displaying miles per gallon (MPG), volts (VLT), intake air temperature (cIA) and coolant temperature (cWT). Both temp readings are...
