Go Back   EcoModder Forum > moorecomp's Profile > Albums
Stealth Kill Switch
I installed a kill switch for my injectors. I used the mechanism in the emergency brake lever to actuate the microswitch.
You can add a bypass switch in case the microswitch fails.
Partial of the wiring diagram showing the common feed wire to the injectors.  This is the one you tap into for the switch.
This is under the center console cover, showing the mounting bracket.
Here the release button on the end of the e-brake is pressed and the pawl is contacting the switch.  No gap at the arrow.
Here is with the button not pressed.  Normal position.  Gap at the arrow.
Radio Shack microswitch.  N/O and N/C depending on how you wire it.
