Go Back   EcoModder Forum > novelinflow's Profile > Albums
State of the Art-Novel InFlow Tech-Development / 1-Gearturbine 2-Imploturbocompressor
State of the Art - Novel InFlow Tech - Featured Project Development; / ·1; Rotary-Turbo-InFlow Tech / - GEARTURBINE PROJECT Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type /·2; Imploturbocompressor; One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is posible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
Imploturbocompressor A and B. %22A%22 as a receiver, and %22B%22 as a generator
Imploturbocompressor Other side A and B. %22A%22 as a receiver, and %22B%22 as a generator
Imploturbocompressor Active Flow
Imploturbocompressor receiver flow
Imploturbocompressor top view cut
Imploturbocompressor view from the top
Imploturbocompressor side view midle cur
Imploturbocompressor front cut at the midle
Imploturbocompressor front view
Imploturbocompressor Isometric Draw
Gearturbine Technical Draw Rotor Parts
Gearturbine Technical Draw More Rotor Parts
Gearturbine Technical Draw lateral Cut
Gearturbine Technical Draw Center of the Rotor
gearturbine retrodynamic effect rotary move vs inflow way
Gearturbine Retrodynamic Effect Draw
Gearturbine Retrodynamic Inside Rotor View
Gearturbine Muy Interesante 4 Scientific magazine
Gearturbine Muy Interesante 3 Scientific magazine
Gearturbine Muy Interesante 2.  Scientific magazine
Gearturbine Muy Interesante Magazine Centerfold from year IX no.10 : 1992 %0AScientific magazine
Gearturbine El Norte Newspaper Automotriz El Norte saturday 20 Feb 1993. Monterrey MX
