Go Back   EcoModder Forum > paddlinphil's Profile > Albums
REvolt
these are a couple of pictures of an electric motorcycle project I am working on.
My niece suggested I inlay some mahogany flames to here they are.
The is the beginning of a new front fender.  The fiberglass cloth is covering the cedar strip fender.  Epoxy resinturns the cloth transparent. It...
The used E-tek motor did not have an end plate.  I had to fabricate one. It includes a double set of ball bearings.  You can see the Sevcon...
After removing the engine, transmission, exhaust system, radiator, and fuel system,  I welded a motor mout for the E-tek motor on the swing are.  you...
This started life as a 1979 Hoda CX 500.  That is a shaft drive twin
