Go Back   EcoModder Forum > EcoModding > Hypermiling / EcoDriver's Ed
Old 05-30-2014, 03:57 PM   #1 (permalink)
1252 MPG via UltraGauge* (screen glitch)
So I was driving home from work the other day and was coasting in my 2003 Jetta (178K miles on it) and looked down and saw my ScanGuage was over 1k instant MPG. Oh the Joy. I have often noticed while coasting the readout is over 100 instant MPG, but this was new territory. Pushing the gas pedal down I saw the 1 was stuck on in the thousandths column-it eventually disapeared. Why would they put a digit in the thousandths column anyway? Wishfull thinking...
Old 05-30-2014, 05:19 PM   #2 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
because it can be mathematically correct as an instantaneous MPG value, depending how the unit plays with the scanner data.
1252MPG at 44MPH = fuel consumption rate of 1 gallon every 28.45 hours. or in a more calculation-friendly value: .0351 GPH.
Old 05-30-2014, 07:01 PM   #3 (permalink)
darcane's Avatar
Do you key-off/key-on or anything else that may rapidly turn the ultragauge off then on?
I see this sometimes on my UG, usually only after it turns off and back on quickly
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 05-30-2014, 08:41 PM   #4 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
No...you have a magic car! You should patent it and start a thread here.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 05-31-2014, 03:23 PM   #5 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
No, no, no, you have one of those conspiracy theory super mileage cars that escaped the factory. Clearly something glitched in the software and switched to the super mileage mode. Set up a deer cam and get photos of the factory tech sneaking out in the middle of the night and fixing it so it gets the same mileage as everybody else.
06 Canyon: The vacuum gauge plus wheel covers helped increase summer 2015 mileage to 38.5 MPG, while summer 2016 mileage was 38.6 MPG without the wheel covers. Drove 33,021 miles 2016-2018 at 35.00 MPG.
22 Maverick: Summer 2022 burned 62.74 gallons in 3145.1 miles for 50.1 MPG. Winter 2023-2024 - 2416.7 miles, 58.66 gallons for 41 MPG.
Old 06-02-2014, 02:39 PM   #6 (permalink)
It happened 3 times before. The extra 1 showes up for about 30 seconds. Neat to see that if I coast i can fill all 4 digits with numbers.
Old 06-02-2014, 05:12 PM   #7 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
Felicia - '09 Toyota Prius Base
90 day: 50.48 mpg (US)
Looking vainly for a down thumb button, or perhaps a Gibbs Slap button.
DO NOT encourage such behavior.
mpg, scangauge
