Old 09-14-2010, 01:25 AM   #1 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.87 mpg (US)
1938 Phantom Corsair
Did a search and didn't get any hits on this one, it looks pretty slick to me regardless of it's actual aerodynamics.
Maybe someone has some info on it?
Google image search- 1938 phantom corsair - Google Search
Old 09-14-2010, 05:48 AM   #2 (permalink)
Zerohour's Avatar
Pooparu - '01 Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '011 Cooper
90 day: 36.4 mpg (US)
People Power - '86 Not Slim
90 day: 5.45 mpg (US)
I would rock that car now. Where has automotive industry gone wrong? I heart to have a vehicle that looks proper in moon hubcaps and white walls.
Old 09-14-2010, 06:32 AM   #3 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Thank you for that pic, I had not seen that car before.
Very nice.
Nissan Versa Aeromods
Old 09-14-2010, 08:25 AM   #4 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
That would make a great Miata kit!!!
Old 09-14-2010, 08:48 AM   #5 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
"electrically operated four speed gearbox"
"front wheel drive"
"fully independent suspension"
"adjustable shock absorbers"
... in 1938?!
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 09-14-2010, 11:08 PM   #6 (permalink)
Wikipedia says it weighed 4500 lbs, had 190 HP and could go 115 MPH?
Sounds like it was gearing/RPM limited?
Old 09-15-2010, 01:32 AM   #7 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
4500 pounds on unbelted radials from 1930's, If it did hit 115mph it didn't do it for long. Also there is a large issue of balancing internals and harmonic dampening. This certainly wasn't as evolved as it is with today's engine.
And I don't think the adjustable shock absorbers were turn knob Koni's, or push button either. They probably had fluid ports to change fluid amount/pressure inside the tube.
Electronic trans probably mean the gear changes were actuator driven. Possibly a push button system from inside the car.
I find conflicting information on the car...it says it was supercharged, but this site said it was NA with Stromburg Carburettor.
General specifications
Country of origin United States
Numbers built N/A (Prototype)
Produced in 1938
Body design Rust Heinz / Maurice Schwartz
Engine
Configuration Lycoming 80º V 8
Location Front, longitudinally mounted
Displacement 4.729 liter / 288.6 cu in
Bore / Stroke 89.0 mm (3.5 in) / 95.0 mm (3.7 in)
Valvetrain 2 valves / cylinder, OHV
Fuel feed Stromberg Carburettor
Aspiration Naturally Aspirated
Drivetrain
Chassis/body body on steel frame
Front suspension independent, semi-elliptic springs, shock absorbers
Rear suspension rigid axle, semi-elliptic springs, shock absorbers
Steering worm-and-nut
Brakes hydraulic drums, all-round
Gearbox Electric 4 speed Automatic
Drive Front wheel drive
Performance figures
Power 190 bhp / 142 KW @ 4000 rpm
BHP/Liter 40 bhp / liter
Old 09-15-2010, 01:44 AM   #8 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Old 09-15-2010, 02:04 AM   #9 (permalink)
Polymorphic Modder
MorphDaCivic's Avatar
2006 DaCivic Hybrid - '06 Civic Hybrid
90 day: 45.16 mpg (US)
I saw this car at the Harrah's car museum in Reno last spring. Awesome car! Awesome car museum if your ever in Reno.
Old 09-17-2010, 03:15 PM   #10 (permalink)
The Toecutter's Avatar
7 inch tall tires on a 16 inch rim gives a total wheel diameter of ~28”(counting tire sag; 30” without sag). With 4th gear of 0.64 and a final drive of 4.70, this yields 116 mph at 4200 rpm. Its gearing is probably correct for its max speed.
What is a good estimate of the rolling resistance coefficient of those old bias ply tires? How efficient do you think the transmission might have been back then? Power draw from DC generator? I’d love to get an approximation of the car’s CdA. I wouldn’t be surprised if the Cd was in the low 0.3 range; it has a frontal area ~24 sq ft judging by the height and width.
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
Rolls Royce Phantom hyperyaris EcoModding Central 8 06-15-2009 03:47 PM
Canadians make 4-wheel version of teardrop Dymaxion car in 1938 MetroMPG Aerodynamics 7 04-13-2009 11:36 PM
Phantom Corsair Q1000 The Lounge 3 03-11-2009 08:12 AM
1938 Gasoline Electric Delivery truck dremd The Lounge 1 10-29-2008 01:26 PM
