Old 08-06-2011, 09:25 AM   #1 (permalink)
2 questions
Hello,
Everyday i do some Hypermiling while working, i've reached interest numbers, but i have some remaining questions:
1. It's better AC on than Windows down. How about if I only open the windows 2 inches? Is it still better AC on?
2. The recomend RPM in highway is between the highest torque and 200 or 300 RPM forward?
Many thanks!
(sorry for my poor english)
Old 08-06-2011, 12:24 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Welcome to the site.
Windows up/down really depends on speed. If you're going 25 mph windows down is probably better. However, at higher speeds windows down and A/C on is probably going to be better. Obviously windows up and fans on full speed is the best, but if heat doesn't allow for it I usually just turn the A/C on, temperature all the way to cold, and keep the fan speeds as low as is comfortable.
Highway rpm really isn't adjustable, so the general rule is slower is better.
Old 08-06-2011, 02:59 PM   #3 (permalink)
Off course, sorry, i forgot to refer that is in highway speeds
I agree.
Windows down and A/C on?! Its a mistake, right?
You mean windows close and A/C on.
Do you realy think the windows only 2inches down is wrost than A/C on?
Old 08-06-2011, 03:33 PM   #4 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I use the windows 99% of the time. the drag is less then the penalty of the AC in my car. but all cars are different.
Old 08-06-2011, 04:07 PM   #5 (permalink)
But you dont open the windows all the way down, right?
Old 08-06-2011, 05:09 PM   #6 (permalink)
Wiki Mod
I do what is needed to keep me cool.
Old 08-06-2011, 05:10 PM   #7 (permalink)
Wiki Mod
the cooler I am the more I ecomodd. if I over heat the nut behind the wheel gets loose.
Old 08-06-2011, 05:51 PM   #8 (permalink)
Kodak's Avatar
Canyon - '07 Canyon 2wd regular cab
90 day: 24.83 mpg (US)
Manguela, you have a good point.
If windows down are better at slow speeds, and AC is better at high speeds, there must be a point where the two intersect and are identical.
Moreover, there may be a point where windows partially down is the same at AC on. I suppose you want to know what that point is. Good thought; sorry I can't be more helpful, but I think that Weather_Spotter is right and it will vary greatly by car.
By the way, your English is pretty good.
EcoDriving: Turning more fuel into usable forward motion.
Old 08-06-2011, 06:47 PM   #9 (permalink)
Yes, I think both of you are right.
I will make some extreme test so i can have some conclusions.
When I have any news I will reply here.
Old 08-06-2011, 06:54 PM   #10 (permalink)
Wiki Mod
I have not done any ABA testing of it but I do know that when I turn on the ac in my car the SG readings drop 2-5 MPG. the windows down has little to no impact at speeds up to 55 MPH, from 55-70 MPH its a toss up (not sure with my tail have not been that fast when it has been hot out). over 70 MPH the AC starts to be better.
