Old 09-11-2008, 02:22 PM   #1 (permalink)
testing the waters
300zx Boat Tail
Hey all I need some help trying to figure the best design for a boat tail for my 87 Nissan 300zx
Photochoppers welcome!
This one's for the photochoppers
http://www.swaqvalley.com/Blueprints...00ZX_Turbo.jpg
I need to know the best slope angle for the rear, I can even raise the hatch a little if that helps.
Old 09-11-2008, 02:37 PM   #2 (permalink)
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy Send a message via Skype™ to SVOboy
Is the airflow attached across the rear hatch glass?
Tuft testing time!
Old 09-11-2008, 03:48 PM   #3 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
according to wikipedia your Cd is should be about 0.30 so that's not a bad start, especially with the small frontal area.
if you draw a line from the top of the roof to the edge of the spoiler you come pretty close to 11 degrees so that's pretty good...
if you fill that in with a solid form you get something like this; wich i think isn't much different from what's already there :
personally id focus on the underside of the car, partial of full undertray, have a good look at the cooling system and see if the wheels could use dams or deflectors... lots of these things are found of modern cars so they really work, since your car is a little older it doesn't have these things but it's basic shape is has to be really decent already, the underside might look a little messy however, so personally i'd focus on thosr areas before venturing into altering the body of the car.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 09-11-2008, 03:50 PM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I agree. That back window is a bit on the steep side for keeping airflow attached. Tuft testing is gonna be needed.
Old 09-11-2008, 06:14 PM   #5 (permalink)
some help
forgottenmindset,if you can locate MetroMPG's thread for his permanent Kammback project,you'll find an aerodynamic template to use as a guide for project.There are instructions for its use.Once you fit your Z-car under the "curve",you can decide how large or small to make your boattail.The template will guarantee you attached flow.No guesswork necessary!
Old 09-29-2008, 02:23 PM   #6 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
I can tell you one thing about the 300ZX...don't block off the scoop area under the bumper...it will overheat even in winter.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 11-26-2008, 05:15 PM   #7 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Just reading some old postings. ( Missed this one )
Are you still interested in seeing your car with a boattail ?
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Tractor Trailer Boat tail trikkonceptz Aerodynamics 23 12-27-2011 06:19 PM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
Diffuser VS Boat tail Vince-HX Aerodynamics 14 09-03-2008 11:56 AM
Rear Wheel Boat Tail Fabrication 2003protege Aerodynamics 1 07-24-2008 05:16 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-30-2008 11:23 PM
