06-10-2011, 09:22 PM
60+ mpg at posted speeds
85.6 mpg
On one run where my previous best was 74mpg in warmer weather than today, I just got 85.6mpg after advancing my ignition timing 2-4 degrees. I posted a detailed "how to" in the DIY section of this forum. But wow! Now I wonder if it is working against my WAI. ??
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
06-10-2011, 09:34 PM
MPG>HP
Nice job! What hypermiling techniques do you use? What kind of commute was it? Highway or City.
Best Tank:36.915MPG|422.6Miles
Longest Tank:35.2MPG|435.8Miles
Best Trip:45.9MPG|5.9Miles
06-10-2011, 09:36 PM
5 Gears of Fury
Good show!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
06-10-2011, 11:09 PM
It's all city, a route I chose for hypermiling when I realized I could greatly enhance MPG by hypermilin down the surface roads and keeping off the freeways. The route goes from about 300-400 feet above sea level to about 100 feet above sea level in about 10 miles. It's kinda down hill a lot. Going the opposite direction I generally get low 50s for MPG. For technique I do all kinds of stuff, but mainly EOC/P&G, which is how the PaleCivic seems to ride and get the top "team honda" billing most of the time. But I route plan, DWL, 1-3-5 shift, and bump start the car on hills when I start out on a trip.
06-11-2011, 10:06 AM
Fantastic! Give yourself a pat on the back and keep up the good work.
Spoken like a champion. Oh no, disaster!
06-11-2011, 01:08 PM
Pishtaco
Kudos! But round-trip averages tell the whole story. Otherwise, it's easy to rack up mpg numbers like this on downhills.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Clean Green Toaster Machine
45.8 mpg over 2235 miles, 164% of '08 EPA
The Following 2 Users Say Thank You to SentraSE-R For This Useful Post:
06-11-2011, 01:47 PM
Absent without leave.
Yep - I can get 98.6 mpg (imp) in Mrs A's Octavia coming home as it is all downhill (we are nearer the coast than work is).
No longer here. Bye, and good luck to all.
06-11-2011, 02:52 PM
Hahaha! Totally true. But what made this noteworthy to me was that for maybe two months I have 5 days a week to get the best possible return on this exact route. Once or twice I hit 74mpg in warm weather. Yesterday, a little colder and without terribly much effort, not more than usual, I got 85.6 mpg. Maybe I drove differently in ways I didn't notice, but an 11mpg gain seems to me LIKELY to be partly about the ignition timing, POSSIBLY. Anyway, it's just a fun report. BTW, I got 102.2mpg on a two mile strip that's flat until it ends in a downhill this morning. But I won't brag!
06-17-2011, 11:29 PM
What octane are you running? Did it seem like you had more power? It's a pretty common mustang trick to run 93 octane and set timing just below detonation. It increased HP and more significantly throttle response. Ya I know it's ecomodder but every once in a while I have to use the spurs on my ride. If it improves performance AND FE even better.-GW
[url=http://ecomodder.com/forum/emgarage.php?do=edit&vehicleid=5154]
06-17-2011, 11:42 PM
Pishtaco
Once might be a fluke. Twice might be coincidence. Three times is a trend. Props for the 85.6 mpg.
Update?
Darrell
The Following User Says Thank You to SentraSE-R For This Useful Post:
