Old 04-14-2010, 10:37 AM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Accessing front turn signals on Scion xA?
Hello,
I am trying to change out the front turn signal bulbs on my Scion xA -- they are tucked up into a tight niche, that has several sharp metal edges. The socket needs to be turned and pulled out, and I cannot get to it well enough with my fingers. There are two large Phillips screws visible that are holding the whole headlight unit in place -- but I removed the screws and the headlight unit still doesn't move.
Any ideas of how I can replace the turn signal bulbs?
Old 04-14-2010, 10:51 AM   #2 (permalink)
Josepha - '08 xD
Never mind -- a small pair of adjustable pliers got them turned, and they come out... It is tight, but doable.
Scion xA aero mods NeilBlanchard Aerodynamics 417 03-26-2012 01:19 PM
Aerodynamic lift- A real problem Hermie Aerodynamics 175 12-05-2010 07:56 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 08:49 AM
Bicycle Turn Signals Lazarus Alternative Transportation 7 04-28-2010 11:31 PM
Scion xA woes Ceyarrecks Introductions 10 01-12-2009 08:11 PM
