...normally I fillup at a brand-name gas station near our house (northwest side of town), but yesterday, because I didn't think I'd have enough gas to make it back home, I decided to fillup at a same-brand gas station near work (south side of town).
...using (A) the same SLOWEST-setting flow on pump-handle and (B) the same "one-click" filling method, I was surprised at how well the SGII fuel value (11.2 gallons) correlated with the new gas pump value (11.238 gallons).
...fast pumping (highest flow rate) is quicker, but tends to create lots & LOTS of gasoline "bubbles & foam" in the tank, making the final "one-click" cutoff far less accurate, because it is 'sensing' the bubbles & foam first and not the actual liquid gasoline level.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
