Old 07-07-2011, 09:39 AM   #1 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Mustang GT
90 day: 24.7 mpg (US)
Acrylic or Lexan wheel covers
Has anyone tried to use hard clear plastic as wheel covers?
I thought of this option for my Mustang because I have 17" 5 spoke wheels that wont accept a hubcap. And a Mustang would probably look a little odd with shiney moon disks. Clear covers would let you still see the rim and give the benefits of a cover. I had also thought about trying to heat it up to get a convex shape. Might work, might not.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 07-07-2011, 10:45 AM   #2 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
It would definitely be more asthetically pleasing to have. Not sure what the best way would be to attach them. You could glue them in place with some gorilla glue, though that would make removal difficult.
Old 07-07-2011, 11:48 AM   #3 (permalink)
Muscle Car Modder
Floordford's Avatar
I was thinking of removing my center cap, because its costly to replace, and from the back side make a round threaded fixture that I can run a small bolt to. I think that might be the best so it wont throw the balance off.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 07-07-2011, 12:27 PM   #4 (permalink)
kir_kenix
kir_kenix's Avatar
1997 Chevy s10 - '97 S10 WT
Pickups
90 day: 27.79 mpg (US)
1997 Ford Escort - '97 Escort LX
Team Ford
This is exactly what I did on my steelie wheels to attatch pizza pans. I made a little spacer on the rim side so the pans had something to torque down against. I had to cut the pizza pans on the edge to fit around my wheel wts and this has kept them from moving once torqued down. I also used purple locktite to keep the bolts from loosening up over time.
I had this set up on my ride for about 5k miles before having to take them off to get tires rotated and I havn't put them back on yet. This time I'm going to find some stainless hardwear so the bolt sticking out doesn't rust as bad.
I really thought that they would end up in the ditch at some point from the center bolt loosening up over time, but this became a non issue for me. I think the same process would work great with lexan, and look better to boot! Probably will have to take them off from time to time to clean all the break dust off the back side however.
Good luck man.
Old 07-07-2011, 02:11 PM   #5 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
If you use lexan or acrylic I would wax it to keep the dust down. I have thought about how it mount covers if I want to keep the look of the wheels. I think that it could work if the rim was removed and a round cover was attached to the inside of the rim then remounted.
I move at the speed of awesome.
Old 07-07-2011, 02:21 PM   #6 (permalink)
acrylic will stay clear, is cheaper but more brittle than lexan (polycarbonate).
Old 07-07-2011, 02:25 PM   #7 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
Acryl wont work because its brakes at impacts. Material needs to be polycarbonate or was it polyester PETG, PET that works also. Here is what I can manufacture if you don`t want to start making your own:
Less drag = Less fuel | Aluminium wheel hubcaps | Eco Tuning --> Tuneko Ltd
Kit would include 4 round PC discs (tinted or clear) and 20 pcs of ziptie plugs and zipties. I can also heat them to little bit convex if you need them like that, so it can be done. Those ERA wheels are 10mm "convex".
Price varies little bit on wheelcover size but it will be between 150-200€ shipped to states. ( just Shipping will cost about 50$)
www.tuneko.com
The Following 2 Users Say Thank You to Vekke For This Useful Post:
ericthemidget (07-07-2011), mcrews (07-10-2011)
Old 07-07-2011, 03:08 PM   #8 (permalink)
Those look good, and thinner/lighter than what people can make themselves
Old 07-07-2011, 04:41 PM   #9 (permalink)
Vekke's Avatar
Diesel
You can make your own with jigsaw but the circle is very difficult to get "round" and looking nice. Material is 3mm thick tinted polykarbonate. Is it 1/8"?
www.tuneko.com
Old 07-07-2011, 09:29 PM   #10 (permalink)
yeah about 1/8"
