03-31-2014, 01:57 PM
Active Aerodynamics Article
I thought this might be interesting, using high voltage ionized air to reduce resistance and drag.
http://www.festo.com/rep/en_corp/ass...Airfish_en.pdf
The Following User Says Thank You to mloveland78 For This Useful Post:
03-31-2014, 05:35 PM
ionized air
The U.S.Air Force investigated ionizing the boundary layer of aircraft in the 1950s using high-voltage.As I remember,this research led nowhere.
It's part of UFO lore,that 'saucers,' utilizing this technology,would not be subject to traditional aerodynamic limitations within the troposphere,stratosphere,etc..
Reason: add extra data
03-31-2014, 08:17 PM
I think Tesla the scientist also played with ionizing the atmosphere around vehicles, however it just prevent the use of radio communications.
Maybe in a honda with lean burn like an insight it can have some measurable effect? Of course got to account for the power needed to generate the ions.
04-01-2014, 11:18 AM
effect
The odd thing about automobiles is that skin friction helps provide the turbulent boundary which is necessary for preventing separation-induced pressure drag,the major component of aerodynamic drag in bluff body flow.This isn't something encountered with aircraft,as fully attached flow is implicit in their design.
04-01-2014, 12:27 PM
PSmodder lurker
A sub-field in aircraft aerodynamics research was to explore manipulating electromagnetic radiation and ionized gas not only for enhanced aerodynamics but also for radar-absorption - stealth technology. They generated wing plasma layers or 'bubbles' and electrohydrodynamic coupling to control airflow both in both high-speed and low-speed ranges.
Cool aero-thermodynamics vids;
Wrangling flow to quiet cars and aircraft
04-01-2014, 12:48 PM
wrangling
I must presume that they intend to fully streamline the vehicle to end separation,then kill the turbulent boundary layer with the plasma,to reduce the skin friction.That would be really good.
04-01-2014, 01:10 PM
PSmodder lurker
...Skunk Works, Phantom Works & sci-fi rumors; for EM stealth purposes, the designs had the plasma generators start at the nose and spaced on all trailing surfaces. Plasma panel surfaces for 'aileron-less' supersonic & even hypersonic designs at critical boundary layer transitions, shock/boundary & shock/shock interactions to - mitigate/eliminate sonic booms!
"You didn't see anything, right?"
Mystery Aircraft Over Texas
Me thinks, a manned EC/strike version.
The Following User Says Thank You to botsapper For This Useful Post:
