Old 11-20-2009, 07:26 PM   #1 (permalink)
1stKIA - '03 RIO RS
Add extra screen/readings to obduino
Hi,
Can I connect a temperature sensor/digital compass to one of the unused arduino pins & have those readings as well on a virtual screen on the obdunio ?
Old 11-21-2009, 03:24 AM   #2 (permalink)
Of course. For example: I'm reading a temperature and the oxygen sensor. But there are few unused pins, and the compass uses i2c. That means you need the analog input pins 4 + 5 for compass but at the moment they are used for buttons. So you also have to rewrite some functions in code (interrupts).
You could move buttons and speed signal to digital IO pins if you use a shiftregister for LCD (there are librarys for this at arduino playground) or rewrite the code for a serial LCD.
Or you can try the same as I do. I'm planing to use a graphic LCD with touch panel connected with i2c. Then you have many free pins to play
Edit: Sorry, maybe it was too early in the morning for posting. You wrote obduino, I thought MPGuino I don't know this one, maybe my writing is wrong for it!
Old 11-23-2009, 01:38 AM   #3 (permalink)
The ISO version of OBDuino has 3 analog pins free, and 4 digital pins still unused.
See: OBDuinoDiagram - opengauge - Whole diagram of the Arduino board, LCD, interface - Project Hosting on Google Code
OBDuino CAN version only, progress! Magister OpenGauge / MPGuino FE computer 26 01-19-2011 10:03 AM
OBDuino help with using iduino kdrlx Instrumentation 1 11-18-2009 06:37 PM
OBDuino Mega jonoxer OpenGauge / MPGuino FE computer 21 10-04-2009 09:06 AM
OBDuino Feature Request... electromike OpenGauge / MPGuino FE computer 13 07-23-2009 03:46 PM
OBDuino and the 328p? gone22 OpenGauge / MPGuino FE computer 0 04-12-2009 10:56 PM
