Old 09-20-2008, 12:58 PM   #1 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
Adding acetone?
I've read the posts on here about adding acetone; it seems that there is no one that really agrees if it works or doesn't and for every person that says they've tried it and it works there's no that says it doesn't. I haven't been able to find anything on the internet from a reputable site that says either way. I guess I’d like to know if there is anyone that has data to show that it does work or doesn’t work. Also, is it possible that adding a small amount of acetone for a couple of tanks could have the benefit for cleaning the injectors to some degree? At least to make it worth doing every 6 months or so. I’m just looking for a reason to either start adding acetone to try it, it add it a couple times to clean the injectors, or to forget about it all together.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-20-2008, 01:09 PM   #2 (permalink)
Silver EP3 - '02 Civic Si
Iv tried it, and got nothing, on 2 cars, both good running Honda's...
Old 09-20-2008, 02:29 PM   #3 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
I got no improvement FE wise, but it did smooth out my idle
Old 09-20-2008, 03:16 PM   #4 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.66 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 42.45 mpg (US)
Could this be something that is vehicle dependent? I've read that some of the Jeep Cherokee's out there get better mileage with higher octane gas depending on which computer it has in it.
I personally use Iso-Heet in every tank. At one point I noticed a big drop in mileage(10.9MPG at lowest). Someone suggested trying some so I did. Noticed a big change after just the first tank. I went back and forth a couple of times and watched the mileage go up and down 1-2MPG's. So I figure it's worth the $1.75 a tank.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 09-20-2008, 04:40 PM   #5 (permalink)
I believe it is vehicle dependent also. Iv heard many swear by it.
Old 09-23-2008, 07:53 PM   #6 (permalink)
Tracy - '00 corsa
i could see it work by leaning out the fuel. acetone contains oxygen atoms. if lean burn works then so would acetone. its the reason biodiesel burns cleaner than diesel.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-23-2008, 10:03 PM   #7 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 metro
90 day: 59.91 mpg (US)
Blue Z - '07 350Z coupe
90 day: 34.13 mpg (US)
HUFFER - '98 Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Riviera Base
90 day: 32.13 mpg (US)
This guy believe's in it. I tried it as an additve and "if" I saw an increase it was only 1 (one) mpg.....And it was probably me driving the car slower....Hoping it would help... I still have some laying around and I will put it in my metro....For kicks...Good luck!
http://www.brightgreen.us/free_tips/...itive_info.pdf
How about a 1 Litre Street rod?
Old 09-24-2008, 01:42 AM   #8 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
As a mileage booster its a scam or a placebo at best. It may have some detergent properties but it there are far better detergents for sale that don't degrade or damage rubber and plastic parts in your fuel system.
Old 09-24-2008, 02:26 PM   #9 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Originally Posted by saunders1313 View Post
I've read the posts on here about adding acetone...
I’m just looking for a reason to either start adding acetone to try it... or to forget about it all together.
I'll let you know how it works out in a couple of weeks!
I'm doing a 'short-fill top-off' experiment right now - topping off my tank every 2 days of driving, blah, blah, blah - then, I'll start the acetone/xylene experiment. I've already got my measuring cups lined up - 33cc & 25 cc, e.g. 1-ounce more or less, respectively.
I'm going to try a mixture of acetone (3 oz.) and xylene (3 oz.) per 10 gallons of gasoline for 1000 miles and see if I can break out of the 41-42 MPG range.
My ride's MPG is V consistent, so the result[s] should be obvious - or not!
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 09-24-2008, 03:47 PM   #10 (permalink)
Yuri4x4's Avatar
TJ - '01 Wrangler Sport
CJ7 - '84 CJ7
Shaggin' Wagon - '07 Grand Caravan SXT
It worked for me in the beginning, but it was probably the 'plecebo effect'... Not long afterward, the fuel pump wnet out on my Jeep. It may or may not have had to do with the acetone, I don't know. But I quit using it anyhow. (and didn't notice a loss of milage)
I do have a friend that still uses it on his Jeep Liberty after 2-3 years, and swears by it. So I don't know.
My opinion is that you can get much better gains just by changing your driving style a tiny bit, and you won't have to worry about melting seals in you fuel system.
Acetone. Lets get to the bottom of this Nerys EcoModding Central 31 07-27-2009 01:55 PM
Adding Acetone as an additive to gasoline - worthwhile? havok95z71 General Efficiency Discussion 14 01-18-2009 11:29 PM
The acetone test trikkonceptz EcoModding Central 88 06-16-2008 10:27 PM
MetroMPG.com mailbag: why don't you test acetone? MetroMPG General Efficiency Discussion 3 05-28-2008 09:54 PM
Video: The Crazy Thing About Acetone. Peakster EcoModding Central 10 01-15-2008 02:47 AM
