Old 03-13-2009, 09:41 AM   #21 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Originally Posted by NiHaoMike View Post
Have you thought about making a charger with a wall wart power supply?
I guess I'm just missing why that would be of benefit to me?
Old 03-13-2009, 10:18 AM   #22 (permalink)
So you can just plug it in to top off the batteries before every trip.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-13-2009, 10:26 AM   #23 (permalink)
CM400E - '81 CM400E
I suppose I could look into that. I know I got an extra one or two laying around. I'll have to check their output voltages.
Old 03-14-2009, 07:01 AM   #24 (permalink)
blueflame's Avatar
The extra battery weight will lower FE.
If the car caught fire insurance may not pay, even unrelated events or if someone hit you first.
I think during starting the cables will really warm as large starting current will come from across all batts (if they are in parallel)
I used to be a sparky but that was a long time ago.
Lower battery voltage during EOC isn't really a biggy.
In fact, mild discharging can benefit some older batteries....
I have some near 4 minute EOC's and my old battery has been okay.
As long as when you park for the night or day at work that the batts have been fully charged from the EOC, battery longevity should be fine.
Old 03-15-2009, 12:40 AM   #25 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Originally Posted by blueflame View Post
If the car caught fire insurance may not pay, even unrelated events or if someone hit you first. . . .
I once had to deal with an electrical short in an old car and the wire literally looked like a 'fuse.' A battery arc driven fire is not something you want to have without provisions to open the circuit quickly.
I would recommend putting a fuse in to protect the battery wire. It is easier to deal with a blown fuse than a runaway short.
Bob Wilson
Local record
Old 03-17-2009, 03:14 PM   #26 (permalink)
CM400E - '81 CM400E
Yes, a fuse would be a great idea should this be more permanent. The wires do not get warm at all when cranking, I checked to make sure. The three batteries share the load, so the amperage is divided by three. The wire, which is only 14 gauge is more than enough according to charts I've seen online that say 14 gauge is good for 32A. That means I can easily pump out 100A, and I'm sure more for shorter durations. The alternator can only supply 60A, so I'm more than safe there.
Blueflame, you are right about the voltage. I did some digging on battery voltages and found out that you can in fact go much lower than I had expected. ~10.5V seems to be the recommended lowest you should go with a battery under load. I've not even touched 11.0, so I will probably end up removing the extra batteries sooner than later. I'll be a bit more aggressive with my EOC next time I drive the car and see what happens.
More smaller batteries vs. Less bigger batteries GooberPea Motorcycles / Scooters 31 01-30-2011 10:44 AM
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 08:23 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-21-2008 11:25 PM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
