Old 05-08-2011, 12:23 PM   #1 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
adding guages
Ok had my car awhile now and have noticed a few things that I dont like. 1) my engine temp gauge has a "L" and then at the top small red line and then "H". Nothing to really indicate what the actual engine temp is. I have watched it to see where the needle is the most consistent at but it its not steady. So I want to add a real gauge with actual numbers. something like this
Blue Digital LED Water Temperature Gauge
2) I have no tach. I want to be able to watch the tach for the best shifts. Maybe get one with a programmable shift light to set it for the RPM I want for say XX MPH. So when i go over that set RPM the light will come on reminding the nut behind the wheel to tighten up. It will be a "Nut Check" light.
Red Digital LED Tachometer Gauge
I already have the MPGuino (yet to be installed) what else would be good to watch? I want to make sure i got everything at once so I can install it together. its a 94 corolla so no one makes a gauge pod for the piller. SO I will have to get my fiber glass out and mold it myself.
Old 05-08-2011, 02:04 PM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Few cars I've driven indicated the actual temperature in °.
The middle position indicates the normal temperature - which is where the needle should be after warm up.
Strange, once warmed up, the needle usually never moves much at all.
Is your thermostat OK ?
Lifetime fuel consumption :
Old 05-08-2011, 03:21 PM   #3 (permalink)
yea I know how the usual temp gauges are on cars too. 95% of the ones I have seen usually have 3-4 dash's between the low and high marks. This one has none, zeros, nada. and like I said the needle fluctuates a lot depending on outside temp, car speed, A/C on or off. If I had to take a guess it really acts like the thermostat is removed or is stuck open.
With no dash's or anything to reference the needle with is the reason I want to put in an after market one.
But not lets not get off topic to much. any other instrumentation? I was thinking of a vacuum gauge also. this way I can monitor engine load vs rpm. and after each mod see if i get + or - results.
Old 05-09-2011, 07:47 AM   #4 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
I'd suggest an AF-ratio gauge, that would allow you to maximize load without enrichment.
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 05-09-2011, 08:17 AM   #5 (permalink)
Above-Average-Miler
abogart's Avatar
EcoCorsica - '96 Corsica Base
90 day: 32.01 mpg (US)
Thumbs up
+1 for the vacuum gauge. I installed one on my car years back. Although I was unable to get it to happily mount anywhere, I found it a great tool for monitoring engine load. Now, with Scangauge, it is second nature to me to monitor MAP as I am accelerating. I actually feel lost driving a vehicle with no manifold pressure instrumentation now.
Old 05-09-2011, 01:57 PM   #6 (permalink)
mcmancuso's Avatar
Green Metro - '99 Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Metro LSi Convertible
90 day: 50.52 mpg (US)
personally I've got a water temp gauge, vacuum gauge and MPGuino, and I'll be adding an oil pressure gauge (never liked the idiot light system, I want to know pressure is low before its zero) Thought about the A/F ratio gauge but they're ~$200 and if you're not going to be changing the A/F ratio then they don't tell you much except to know when the car is in closed loop...
