Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 08-23-2012, 04:30 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Adding an overdrive (BW T-19 to ZF-5 transsmission swap)
If you’ve never driven a vehicle more than a couple decades old, you probably take overdrive for granted.* You may not even have a clear idea what that term means.That 5th or 6thgear, with a ratio smaller than 1.0 (meaning the driveshaft is turning faster than the engine) lowers the engine RPM speed on the [...]
More...
The Following User Says Thank You to SVOboy For This Useful Post:
bobo333 (08-23-2012)
Old 08-23-2012, 06:31 AM   #2 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
YES! This is exactly what i need to do in my '77 F100!
i will be watching closely, thanks
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
