So my car is a 1995 acura integra sedan. I bought this car mainly as a back up to my cobalt. It gets pretty decent mpg so far but I thought about adding a secondary fuel tank to the car. I mean there isn't really a great reason for doing so but I thought why not. Other than getting a fuel tank to go into the trunk. What else would I need for this? Would I need a secondary fuel pump? My idea is to have a second gas cap so I can put fuel just in this tank, then flip a switch and a small fuel pump pumps fuel from the back up tank into the secondary one. I would have to run a line from the second tank to the main one. I'm all up for advice on this matter. Thanks.
Not sure that this is really the best idea. Unless you are hwy driving, you will loose FE and, really, if you are on the hwy, can you go 5 hrs without a break? I start to kill people.
eh just longer range really, it would save me from having to fill up at the pumps more often, idk I wouldn't mind that. Just one large fill up at the beginning of the month then I wouldn't have to fill up for a month. It it legal though?
If you really want to do something like this then getting a fuel tank that fits in the spare tire well like is used for waste veggie oil in diesel cars is most likely going to be the safe and easy way to go, but the cost and time you are going to invest in adding this 2nd fuel tank, you would come out ahead by doing other things that would get you better mileage, or if it's the time then the added time to install a system like this compared to the time spent at gas stations is going to take years to brake even.
