Old 05-01-2009, 02:25 PM   #1 (permalink)
aero caps and wheel balancing
With making and installing DIY flat aero hubcaps, I prefer to move the balance weights all to the inside of the wheel rims, so I don't have to work around them. A tire shop says no problem. (I imagine they do it for looks on fancy rims all the time.) But a friend says my wheels will not be balanced as well. I thought I might get some more opinions here.
Old 05-01-2009, 03:23 PM   #2 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 42.99 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Dynamic (tap on wheel weights on the inside and outside rim edge) offer the best balancing as they are able to take car of the "up-and-down" and some of the "side-to-side" weight differences.
Static (stick on weights in the inside of the rim) can only really compensate for the "up-and-down" weight difference.
If the guy balancing the wheel is good then you won't notice the difference between teh two types of balancing.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 05-01-2009, 05:32 PM   #3 (permalink)
Eco Dreamer
Versa - '08 Versa SL Hatchback
Actually there are 2 ways to do sticky weights. The first is what TomO is referring to, when then just put the weight centered on the inside of the rim. Most alloys use 2 spots for sticky weights, weight on the inside of the rim, and weight just behind the spokes.
You'd be just fine going with the 2nd option.
Old 05-01-2009, 07:54 PM   #4 (permalink)
Yes, (if I read you right) since I don't care where the sticky weights go, so long are they are below the hub cap ledge, I can still achieve the optimum type of balancing by placing them near where crimp-on weight would go, as I now understand things. It may be a matter of using just slightly different amounts of weight, but the effect will be identical, I think; the balancing of the wheel can still be perfect. Thanks for responses.
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-16-2009 12:55 AM
"Pizza pan" hub caps (2008 Civic)? KJSatz Aerodynamics 2 08-05-2008 01:14 AM
Low budget aero hubcaps jim-frank Aerodynamics 30 06-02-2008 03:06 AM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 06:23 PM
