After taking a drive I am pleased with the results. Less wind noise for sure. The holes point directly into the suspension so blocking that off should save lots of turbulence. I plan on using Bondo to re-create the curves of the bumper and blend it in better. Then I will paint. Hopefully the plates will be invisible by the time I am done.
