Old 04-07-2008, 12:00 PM   #1 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
Thumbs up Aero hubcaps
I know most of you are more DIY oriented, but I found some prefabbed pizza pan wheel covers.
Mooneyes manufactures racing wheel covers for 12-15" rims.
Hubcap Mike carries them in 12-16" sizes.
I am ordering from Mr. Mike later today, I'll let you all know how it goes.
Old 04-07-2008, 12:05 PM   #2 (permalink)
I REFUSE!
thebrad's Avatar
Forgot to mention, there are two styles - clip on or screw/bolt in.
Application pictures if you are curious
Old 04-07-2008, 12:34 PM   #3 (permalink)
"Fluid Dynamic Drag" by Dr. S. Hoerner, page 13-14 shows drag coefficients of various aircraft wheels. The ones most like those shown above have the lowest drag, as you would expect.
Old 04-07-2008, 03:47 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I would go with the lightest weight hubcaps you can get, not sure if the stainless steel is thin enough to be lighter then aluminum or not.
Old 04-08-2008, 08:13 PM   #5 (permalink)
I REFUSE!
thebrad's Avatar
Well, some bad news, I didn't pick them up Monday as planned because I forgot I had an appointment before class. Anyway, called Hubcap Mike up today with some technical questions and to check stock before I headed out to pick them up. So the "pop-on" style (hubcaps) only work on steelies, I had figured as much but thought I would be able to come up with some clever way to mount them. So the wheel covers (screw-in) are made to order by Mooneyes, and take about 5 business days to complete so there goes my plan to test out simple aero mods on my upcoming trip.
As far as weight is concerned they are listed at 1 lb. each, easy enough to compensate for that addition of weight.
Mounting the screw-in type requires dismounting the tires and drilling into your rims...
Old 04-09-2008, 01:08 AM   #6 (permalink)
BE sure the drilling does not compromise the strength of the wheels, or allow corrosion.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 75 03-01-2012 07:28 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 06:03 PM
Aerodynamic hubcaps with holes for lugs/air valve? Bob64 Aerodynamics 8 04-01-2008 05:34 PM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 12:34 AM
New user intro and pick-up aero modding Blackbird Aerodynamics 4 01-28-2008 12:06 PM
