Old 07-03-2011, 10:48 PM   #11 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
I can't help myself....
Droodle droodle
The Following User Says Thank You to ChazInMT For This Useful Post:
joshuachance (07-04-2011)
Old 07-04-2011, 12:19 AM   #12 (permalink)
@ChazInMT
Interesting that there is an 'aero template'.
Thanks for the pics with it already averlayed on a metro (even the right body for my year).
Where does this template come from? It has been hard for me to find the more 'meat and potatoes' reseach on things like laminar flow (wich it looks like is the intention here). Granted, my own contributions so far are mearly like a garnish or salad dressing... ha ha, I love analogies...
But seriously... um, I have thought about a larger plate in the very back, so that these arches are not as dramatic on my car. Actually I increased the plate already on my 2011 version a little. Only about 2 inches on both the height and width of the back plate. Not much...
It is difficult, i'm sure for many, to want to stray away from something shorter and eventually end up with a compact car longer than a small bus.
Also, anything about the trailing edge mods to sever that laminar flow without creating so much vacuum?
Mostly, any citation to some good research on this 'aero template' would be great!
Also, what are the reasons for keeping the lower portion of the template so close to the ground? Is that due to the benefits of a lower profile to help eliminate the turbid flow from all the landscape underneith the vehicle?
Yet another relm for me to think about now. Ha ha, I love it!
Thanks again,
JoshuaChance
Old 07-04-2011, 02:40 AM   #13 (permalink)
Tenderfoot
ChazInMT's Avatar
Lotsa good back & forth in this thread, in the end I concluded we were both right, flow separation occurs at 23° no matter the placement of the template, however, in order to achieve low Cd aero dynamics, you need to put the template under the wheels. Just cause the flow is attached, does not make it efficient. My theory is a lift drag is created by a too aggressive drop like your proposed boat tail and my 1st gen aero cap. I think the air needs to "build in under pressure" in the back of the vehicle to avoid a dynamically produced low pressure. Don’t worry about a larger "flat spot", you are much better off following the template.
flow separation:Tiger Woods meets Cinderella,or 5-seconds to a perfect roofline
Here is the thread with a lot on the template as well.
Aerodynamic Streamlining Template: Part-C
And here's where I get the % data from:
Aero drag reduction potential
This thread puts to numbers the fact that if you chop off the tail of the ideal aero shape, you really don’t pay a huge penalty for it until you get to around 20-30%.
Hope this serves as some meat & taters for you, I know that this website over the last year and a half has brought me a long ways towards better understanding this stuff.
Old 07-04-2011, 04:04 AM   #14 (permalink)
@ChazInMT
Excellent!! Thank you very much...
"I think the air needs to "build in under pressure" the back of the vehicle to avoid a dynamically produced low pressure."
This is something i've been thinking about a lot sitting in my garage tonight (enjoying a few frosty beverages).
I mean, when the very tail end of the 'tail' is tapering off from both the top and bottom, and also both sides... I think there may be too great of an area where the air is all trying to fill the tapered empty spotsand then create too much low pressure...
Just a quick thought. But something to consider. Thaks!
JoshuaChance
Old 07-04-2011, 04:37 AM   #15 (permalink)
Sorry... don't wanna go off on too much of a tangent maybe more appropriate for another thread...
@some other dave
Yes, totally see all the campaign signs around... they just took them all down here a month ago...
So, I stopped by a couple of the local 'sign stores' here this week the see if they had corrugated plastic I could buy from them. It was harder than I expected! Many didn't have it in larger sizes, and the ones that had 4' x 8' sheets wouldn't sell it as stock. They wanted $100+ for them with the condition that they printed on it themselves.
I found a few sources on tha interwebs that sold 4' x 8' sheets, but they want $20 to $30 a sheet (depending on thickness), and required a minimum of 10 sheets per order... no doubt I could use ten sheets at some point for some project... but 300 bucks all at once in hard to choke down.
I think the campaign signs will be hard to glue all together, but kinda considering it at the moment. Maybe if I swing by one of the sign places and see them face to face, they may reconsider based on the 'cool' project I am attempting. Wishfull thinking, ha ha.
Thanks again
JoshuaChance
Old 07-04-2011, 05:06 AM   #16 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
did some aero metro sketches a while back, so just for fun here they are
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
aerodynamic, boat, metro, swift, tail
