01-19-2017, 10:53 PM
Celtec expanded PVC sheets for aero mods...
Just look up this stuff on Amazon, it's pretty cool... Light, heat formable with heat gun, and seems strong enough for aeromod use... Best of all, it presents a more finished look than coroplast, and doesn't cost much more(unless you're getting the coroplast for free)
My current Ecotec project...
My last Ecotec project...
The Following 3 Users Say Thank You to 19bonestock88 For This Useful Post:
01-20-2017, 12:52 AM
The Following 2 Users Say Thank You to Xist For This Useful Post:
01-20-2017, 01:43 AM
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
Confirmed, i briefly used it for my wheel skirs and love the stuff. Here they sell it as " foamed PVC" under different brand and claim good UV resistancy. Plus, you can glue it with toluen based glue.
The Following User Says Thank You to seifrob For This Useful Post:
01-20-2017, 01:49 AM
Moderator
I've been looking for a source of cheap PVC sheet to make wheel skirts. PVC has excellent UV resistance, unlike polypropylene Coroplast. Nice find!
01-20-2017, 08:52 AM
I have a sheet of this stuff I bought last year for a large scale hovercraft model.
Life and business intervened and the sheet sits in my studio untouched.
The sheet I have is rather thin and bends in a nice smooth arc. That arc was to be a main feature of the model.
If you are looking for something stiff go thick, if you want to bend it go thin.
My local plastics shop carries all sorts of plastics, the owner is super friendly and walks me though. I tell him what I'm trying to do often with a sketch and he immediately knows the best product because he also fabricates specialty products in his shop.
01-20-2017, 09:22 AM
I was looking at this material for potential wheel covers the other day...!
But maybe not:
https://en.wikipedia.org/wiki/Closed-cell_PVC_foamboard
One drawback to PVC materials is that hot working them produces noxious fumes containing hydrochloric acid and potentially even dioxins. These are a respiratory hazard in a workshop, and the acid fumes are so serious that they may damage equipment. Some heat-based processes, notably laser cutting, are generally considered impossible, owing to the equipment risk. Where PVC materials are cut by laser, this is a highly specialized process requiring adapted machines and acid-specific fume extraction and filtering.
If it rubs or burns in any way it can get quite nasty.
Be safe.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
01-21-2017, 05:28 AM
The most I've done with the stuff was use a heat gun to bend it, but I imagine it can't be used in the engine bay or near the exhaust.., I mainly plan to use it to fabricate a more permanent lower grille block, once I have the shape worked out so my car won't overheat, and a pair of wheel skirts that look better than the coroplast I used before...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
