Old 11-09-2010, 11:03 AM   #1 (permalink)
Building the future! :-)
Thumbs up Aero reverse trike project: Ninja 250 or Lifan 200 with electric assist/EV mode
Hi Guys, ive been lurking a while and have been a bit more active over at the EV forums.
Here is the plan:
I have built 5 reverse trikes so far, this will be a 6th. Ill likely use a ninja 250 motor or possibly a lifan 200cc as "gears 3 through 9"
Here is what I mean...
The trike will have a 12v winch motor (4.8 hp rated pushed to 24v and about 7 hp) serving as reverse and low gear for taking off, the electric motor will take the vehicle up to about 20 mph then "retract" from its own seperate drive chain (looking for input on a design for this)
After that, the gas engine would take over.
The trike will have about the same frontal area of a motorcycle 8.5 sq ft and hoping for about .16 or .17 cd so cruising hp should be between 5 and 6 by my math.
The idea is to gear the gas motor so its 5 or 6 gears (Kawi or Lifan) so its 1st gear is what its 3rd gear is (if that makes sense)
Any input or ideas would be most welcomed :-)
Tom
Old 11-09-2010, 01:48 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Tom - sounds fun! Have you started the project yet? If so, you should definitely start a thread to document it here.
Old 11-09-2010, 03:03 PM   #3 (permalink)
Just getting the first bars of steel cut :-) I also have a build log over at belaero.com
Heres a fun dilemma, any engineers in the house?
for this to work, the winch motor has to disengage from whatever sprocket or gear its on while driving the wheel at low speeds.
Anyone have any links to successful instances of this? say reverse on a motorcycle?
Heres one way I was thinking it may work:
Use a 1/2" wide flywheel ring gear, fab a center section for it and mount it outboard of the drive sprocket on the wheel.
Then mount a pinion gear on the winch motor and mount the motor on a "track" so it can be moved toward and away from the ring gear.
Think this would hold up?
Old 11-09-2010, 06:19 PM   #4 (permalink)
AeroGuy
eco_generator's Avatar
4x4 Wagon - '89 GL Wagon 4wd
Subaru
90 day: 31.58 mpg (US)
Fromeo - '07 Fit Base
90 day: 46.09 mpg (US)
Some sort of clutch would be best. When you downshift... is there going to be a switch on first gear that shuts the engine off?
Old 11-09-2010, 06:45 PM   #5 (permalink)
Split the discussion into its own thread, Tom. I think you'll get more interest/participation rather than buried in Bryan's thread.
Old 11-09-2010, 06:56 PM   #6 (permalink)
Thanks Metro :-)
Eco-G Im thinking no clutch because the only times the e-motor will be used is 1st and reverse, first, it goes then removes itself from the drive line, reverse, same.
I can live without downshifting into first from a higher gear I beleive.
Old 11-09-2010, 09:22 PM   #7 (permalink)
You could use an electromagnetic clutch.
Too bad the motor has to run both directions - if you only needed one direction, you could use a sprag clutch.
Old 11-09-2010, 09:25 PM   #8 (permalink)
This may well be in the forums in one place, but ill ask anyway.. :-)
On a motor like a ninja 250 or a lifan 200, what are the most popular engine mods (that don't necessarily take the power level down) freeflowing exhaust, and close attention to the carb jetting, any other fun tricks?
Old 11-09-2010, 09:39 PM   #9 (permalink)
Boreas's Avatar
I was thinking maybe an electric clutch from a car air conditioner. You could use a switch to control it. I think it would work in reverse but I'm not sure. Has anyone tried to run an AC clutch in reverse?
Old 11-09-2010, 11:14 PM   #10 (permalink)
Lean burn - '89 Civic Wagon DX
Elle - '03 Element EX AWD Auto
I think the electric reverse on motorcycles uses the starter motor. A solenoid that engages a toothed drive sprocket like a starter would be a good way to do it. Only issue is if you fall out of the "3rd gear" power band you would need to stop to be able to use the electric motor to get you going again.
or a simpler solution...
How about having the electric motor drive one of the front wheels and the gas motor drive the rear wheel.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Project Slipster: Streamlining the Kawasaki Ninja 250 (WIP Thread) theycallmeebryan Aerodynamics 81 01-14-2012 06:56 PM
Electric Cars Push Japan Engine Parts Makers to Crisis Mode tjts1 The Lounge 12 01-17-2010 12:23 PM
