Old 01-07-2013, 01:28 PM   #121 (permalink)
Originally Posted by kafer65 View Post
One thing, turbo is load sensing irrespective of rpm. If you make more aero improvement s or slow down to reduce aero load the boost will subside even if your at max rpm. Changing to as smaller gear may put you where you have an increased load on the engine and increased boost even when your rpm is reduced. Great job, buy the way. I have an old dodgeslant6 pickup with 3.55 gear and I only get 13mpg empty. I'm so ready to put an airdam and aero bed cover together now.
Yes I have that debate going on in my mind. I started to do that with my Saturn and after finding some torq/horsepower/rpm charts on it I decided I might be going backwards with lower gearing. I shaved the side mirrors, did a total block off of the front grille and covered the head light nacelles with plexiglass and I'm averaging a bit over 50 mpg straight and level with no A/C. I'm happy with that a far as the gearing. Next up is a complete set of wheel fairings and maybe belly pans.
Old 01-07-2013, 02:05 PM   #122 (permalink)
NASA paper
NASA paper:
www(dot)nasa(dot)gov/centers/dryden/pdf/88628main_H-2283.pdf
(Sorry, I can't hotlink it as a new poster here.)
A brick with a .24 Cd, really cool. Love to see an RV built with the shape they developed.
The Following 4 Users Say Thank You to ennored For This Useful Post:
Flakbadger (01-13-2013), HHOTDI (01-14-2013), orbywan (01-07-2013), t vago (01-07-2013)
Old 01-07-2013, 05:07 PM   #123 (permalink)
Originally Posted by ennored View Post
NASA paper:
Yeah, that's it. Thanks for posting it.
Old 01-07-2013, 05:09 PM   #124 (permalink)
Originally Posted by rickjames8 View Post
I guess it does come down to skill sets. For me, I'm more intimidated by welding a steel frame. Having never welded, it seems like a much more precise skill....
Work with what you're comfortable with or look it as an opportunity to learn something new. It's good either way.
Old 01-07-2013, 05:50 PM   #125 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 13.11 mpg (US)
The Karen-Mobile - '05 Magnum SXT
90 day: 21.95 mpg (US)
NASA paper:
http://www.nasa.gov/centers/dryden/p...ain_H-2283.pdf
RIP 2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine - 12 OCT 2002 to 20 JUL 2012
The Following User Says Thank You to t vago For This Useful Post:
Old 01-08-2013, 06:17 AM   #126 (permalink)
Civic VX - '-1806 Civic VX
You're absolutely right. I think I might see about getting a welder and seeing what I can do. I have a few friends locally who've welded before who could give me tips and I would trust them to check my work before roaring off down the road at 55mph.
I plan to buy this RV at the end of Feb with a planned departure at the beginning of June. I'm trying to list out all my mods now to work out how long it should all take. Not that I've ever had a plan stick to a timeframe before.... ;-)
Old 01-08-2013, 09:22 PM   #127 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 19.36 mpg (US)
Start a thread for it. Link it back here.
And thanks for waking this one. I always get pumped when it shows back up!!
2004.0 7,940-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock. 187,000 miles/4,800-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (21-mpg avg past 41k)
Fuel Log
Old 01-18-2013, 01:38 PM   #128 (permalink)
I've posted in a couple threads about boattails, but not here, where I first was drawn to Ecomodder.
In the beginning of this thread you mention that you kind of just guessed a taper for your boattail. You say it's just over 4' long. Just how much does it taper in? Did you lay out the curved part, or simply eyeball it?
Thanks.
Old 01-18-2013, 03:54 PM   #129 (permalink)
Thanks.
There is 18 inches of taper occurring on the first 24 inches of the 4'6" of each rib. I made a 'control' rib of that specification and pounded out each of the 28 ribs to match the control. The taper occurs in the first 24 inches of the length of the rib, instead of the whole length like I probably should have done it.
I did it that way because I was flying along in a J-3 Cub once a long time ago and watched some water vapor moving over the top of the curved wing surface and down the extended aileron as we turned, without separating, and that shape stuck in my mind. So I made my ribs like the Piper wing.
In retrospect that was pretty dumb, but it did still have a great effect on mileage. Once the front mods and the wheel pants are finished I'll do some more testing and maybe make the tail conform to the holy template, or not, depends on how it does and how much time I can spend on it. I have had zero time for months and it's making me crazy.
The Following User Says Thank You to orbywan For This Useful Post:
aerohead (01-18-2013)
Old 01-18-2013, 07:22 PM   #130 (permalink)
"There is 18 inches of taper occurring on the first 24 inches of the 4'6" of each rib."
You mean the skin on any side is 18" from the front in only 24" along the skin? Or 18" total narrowing on both sides? And it's basically straight after that? And the ribs started 4 1/2' long? Of the finished tail is 4 1/2'?
What is the total taper? It starts at 96" wide (or close to that) and narrows to what? Maybe 48" (half) judging from the pictures?
Just trying to get in my head what it looks like vs. the Dryden (and other) tails for my graph in the other thread.
Thanks!
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
