Old 11-21-2010, 01:59 PM   #11 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
Cut a bunch of 3" long pieces of yarn, tape them to the surface of your car about 6" apart each way, then drive down the road at various speeds while you, a friend, or a video camera observes the behavior of the yarn in the air flow. In an attached airflow, they will all point in about the same direction with very little jumping around. In unattached or recirculating airflow, the yarn will be jumping around in all directions. Google "yarn tuft testing" to see photos and videos of it.
Old 11-21-2010, 02:50 PM   #12 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Basjoos - still waiting to see a tuft test of your car. Surely I'm not the only one on this site that would love to see that.
Whuups ... didn't mean to hijack the thread. Getting back on topic, it is actually possible to add wheel arches to a vehicle and not increase the frontal area all that much.
Looking at the wheel arches on the Ford Focus, you might notice that the arches actually don't protrude all that much from the sides of the vehicle, yet appear to do so because of the clever use of a body cavity.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 12-06-2010, 01:06 AM   #13 (permalink)
Originally Posted by KamperBob View Post
Wind tunnels are expensive. Tufts are cheap. ABA testing is where the rubber meets the road. Full tank testing can be expensive and that kinda of data tends to be dirty (mixed inputs). A ScanGauge is your friend. Cardboard prototyping is prudent. Be scientific. Document everything. Learn from every improvement and setback. Take pix and share so others can help. A happy ending is inevitable.
Cheers
KB
I'm kinda thinking I will have to have to make a few scale shapes from wood and see if I can get a college's VRI to test them for me.
My basic understanding, is that 12* is the max angle change to prevent air separation. So , in theory, if I angled the sides of the front fenders inward no more than 12* from the front wheel opening forward, and followed that same rule all around as much as possible, it should yield good results.
My design I've been drawing on for over a year now is pretty radical. 40" tall and just under 13' long, single cam honda engine mid mounted with the radiator in the chopped boat tail. To save weight and height there is no seats, the cushions go right on the floor. ~25* layback on the seats allows occupant height up to 6'-6", and surprisingly it's pretty comforatable(tested by blocking a racing seat and measuring. Lastly, I currently have a airflow channel down the bottom center of the vehicle. At the passenger compartment it measures 1 foot wide and 18" tall and it tapers wider and slightly taller at the front, only impeded by the steering rack and shift linkage. At the engine, an upside down wing shaped oil pan will help ramp the channel air under the motor. The rear boat tail will truncate at ~10" tall, the sides consisting of the tailights and the center being radiator drawing the air into the void at the truncation(thru the radiator).
My biggest worry at this point, is that the front will be so light it could get ugly at speed. I need to carefully shape the nose to produce a slight amount of downforce as speed increases. It's my hope the air accelerated under the car and thru this "channel" will do just that while decreasing drag.
Old 12-13-2010, 04:24 PM   #14 (permalink)
angles
W.A.Mair's research concluded that body tangent angles up to 22-degrees could maintain attached flow if the form leading up to it had gently progressive curvature.
If you haven't seen the 'Aerodynamic Streamlining Template - Part C' you may want to do a Search EcoModder for it.This template was created for anyone wishing to design for attached flow and it can be used for micro as well as macro environments.
Any discussion of 'angles' should include the contextual environment in which they are to exist.
Also,if you do models,make sure the wind tunnel is fast enough to provide for scaling effects / Reynolds number.
KamperBob (12-13-2010)
