10-26-2008, 11:35 AM
#11 (permalink)
Ultimate Fail
This is getting interesting.
I had never seen a single wheel trailer.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
10-26-2008, 11:40 AM
#12 (permalink)
Phil's DIY aero trailer had a single wheel:
There's a double-wheel aero trailer in his album too:
10-26-2008, 11:53 AM
#13 (permalink)
Ultimate Fail
Here is a quickie image of the Flea dropped around 2 1/2 " with an aerotrailer.
10-26-2008, 03:51 PM
#14 (permalink)
If the trailer wheels don't provide side force in a turn or to counter side winds, I think it is better just to build a super-light tail. A big egg-crate construction of Coroplast is plenty strong enough.
10-26-2008, 05:54 PM
#15 (permalink)
Boxhead
True, but a trailer has utility value, as well, and can be uncoupled fairly easily. It's not a bad way to go, really.
10-26-2008, 06:22 PM
#16 (permalink)
Yes, a conventional, single pivot trailer can carry lots of weight with far less effect on stability. Swivel-wheel trailers should never be expected to carry a useful increment of weight without upsetting the handling.
10-26-2008, 08:46 PM
#17 (permalink)
Addicted
Darin, I like the first one of Phil's the second not so much.
The trailer I would like to build would have a hinged top. I am not camping in it just using to haul my camping/ fishing gear. I was thinking along the lines of using front motorcycle tires with custom axle. I could even cover the wheels with something to make the rim entirely enclosed, and also do a full belly pan on the trailer.
I was just thinking the motorcycle rims/tires would not add much RR. The weight of trailer fully loaded would probably be somewhere in ballpark of 400-500lbs. If not even lighter.
Single wheel trailer from doublehitch.com I like that idea, would be cheap to build. Also easy to aero mod taper the rear easy with only one tire.
10-27-2008, 10:43 AM
#18 (permalink)
Beta-tested it to death!
Hey bbjsw10,
I have a home built "teardrop trailer" camper, which I pull with four cylinders.
Most traditional teardrops really aren't that aerodynamic. The sketch you have at the top with the tapered sides looks like a great variation on it though.
I had a thread a while back about somebody elses teardrop which actually improved the fuel economy on her pickup truck while she pulled it. The had a 6-cyliner truck with a cap on it. I think her teardrop became a "tow-along boat-tail"!
I also talked to this guy a while back, who built his second teardrop trailer with aerodynamics in mind.
I know it was mentioned in your thread on the Metro Forum, but if you haven't yet, make sure to check out Teardrops & Tiny Travel Trailers :: Index it is THE PLACE for small and retro trailer building!!! That's where I got started working on mine.
10-27-2008, 01:22 PM
#19 (permalink)
This was an idea from another thread, but how about build a lightweight aero shape around a hitch drawbar, then you can easily remove it? Wire your extra lights to a trailer harness that can plug into the car end.
But the idea of doubling as extra carrying capacity is nice.
Winter daily driver, parked most days right now
Summer daily driver
10-27-2008, 06:06 PM
#20 (permalink)
Addicted
Originally Posted by bennelson
Hey bbjsw10,
Yeah I saw your Pics of teardrop you built.  Have been thinking of it ever since seeing it.
I am aiming for the "tow-along boat-tail" effect. That is why I am aiming for that shape.
No pic on brokenhammer?  I want to see it. Ideas!
Thanks for the link will look at later tonight.
I need a project for winter to keep me busy, I think this may be the one. Plus if I can design it to help mileage on long trips I may just pull it anyway.
