Old 05-13-2008, 02:21 AM   #21 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Awesome..
You've gotten the bug back up and running for me now!
I dig how seeing other peoples projects lights the fire back under my ass.
I love the cover.. Whats the white materal you used to cover the PVC frame?
as for inbetween the cab and bed, use some of that foam insulation stuff made for water pipes and that mite help? Rollbar padding? Expansion foam?
I'm just the idea guy..
Rather they work is for the engineering department to figure out
Old 05-14-2008, 06:02 PM   #22 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
How'd you get paint to stick to the FRP? I'm driving pretty much the same rig and am getting ready to replace my old flush-top cap with an aero like this one. I'll be shooting new paint onto the truck at the same time, so it'll all match up and look stock.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 05-14-2008, 06:15 PM   #23 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 pickup plain
90 day: 32.08 mpg (US)
ok, sit back and try not to laugh too hard whilst I fill you in....... I got some paint from Wally-world for 98 cents a can. I used 8 cans on the truck. The cap and skirts took six more. I used some scotch-Brite pads to scuff up the FRP. I do not know how long it will last, but so far has held up well to two washings and a wet week of highway rain.... Whatever you do, make sure you purchase a spray can trigger! My finger was blistered after the first three cans. This whole thing started last month when I kept looking at this wore down, beat truck sitting in my driveway going to waste. I painted it, drove it, then got the Ecomodder bug!
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 06-01-2008, 10:50 PM   #24 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Hey Kevlar,
Two weekends ago, I tried playing around with a wood frame with greenhouse glazing over it for an aerocap.
I had problems with trying to get the wood angles to work right. I am not much of a carpenter, and it really didn't work out.
It looks like with your pvc pipes, you were able to make angles work by using PVC T-connections as a swivel.
I see lots of screws in the photos. Did you just use self-tapping screws straight through the FRP into the PVC tube?
Did you have any trouble while heating the panels to bend them? Any over melting, or heating the tube underneith?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 06-01-2008, 11:28 PM   #25 (permalink)
penny pincher
kevlar's Avatar
"It looks like with your pvc pipes, you were able to make angles work by using PVC T-connections as a swivel." -
A little swivel and (don't tell the wife) heating of the PVC in the oven to about 110 degrees, then I was able to "form" it to the shape of the cab.
"I see lots of screws in the photos. Did you just use self-tapping screws
straight through the FRP into the PVC tube?" -
I used the self-tapping screws to hold the shape ( careful not to over torque)after I heated it, and pushed it slowly into shape until I could fasten it down, leaving the screws. I then backed up the screws with 1/2 inch saddle straps, nuts and bolts from the inside.
"Did you have any trouble while heating the panels to bend them? Any over melting, or heating the tube underneith? "-
At first, I was heating too quickly and switched to a further, lower heat with a wide flame adapter. If you heat with long, sweeping motions, watch, bend on the line you want, you should be alright. kind of like making the panel rubbery at the line of bend.
how it was done...
Old 11-03-2008, 10:19 PM   #26 (permalink)
penny pincher
kevlar's Avatar
Originally Posted by kevlar View Post
thanks for the input! Now that you mention it, I bet ice shield rubber would work well. as far as the view goes, I haven't yet cut holes to view backward, but plan to in the near future Attachment 716 The original patient.
PVC frame
Attachment 717
I used a bottle torch to bend, heating slowly,following natural drop angle
Attachment 718
Just an update to some questions on this thread.... I have since sold the truck to a welder who reinforced the frame and uses it for hauling. The paint held up great, and the cap never lost shape all summer! :0
how it was done...
Old 07-01-2010, 08:39 AM   #27 (permalink)
penny pincher
kevlar's Avatar
Hi all, I'm Still lurking about once and awhile, but I still have nothing worth modding yet. I hope in a month or so to be getting a '97 Tercel... then the bug will bite again!
how it was done...
Old 07-01-2010, 08:30 PM   #28 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Once again...re-gearing isshown to be a potent strategy.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 11-22-2011, 09:47 PM   #29 (permalink)
EcoModding Minded
Chris D.'s Avatar
any long term updates?
Old 12-17-2011, 12:29 PM   #30 (permalink)
penny pincher
kevlar's Avatar
new update to an old thread. The current owner of the truck added a tall rear end gear and still uses the truck regularly between north and southern Indiana and tows a trailer with it. He says he gets a pretty steady 32-36 mpg's out of it.
how it was done...
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 34 11-12-2011 11:45 AM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
ToyotaNation truck forum freakout: "would you put this (aero) cap on your truck?" MetroMPG Aerodynamics 72 01-07-2010 05:25 PM
Toyota concept aero truck LUVMY02CREW The Lounge 14 11-14-2008 12:16 PM
More Pickup truck Aero bennelson Aerodynamics 16 05-13-2008 09:32 PM
